Question about Roper Washing Machines
How can i get the lid to open if the lock wont unlock
It is a roper washing machine and the lid lock light was flashing and kept repeating the final spin cycle and it will nit unlock to open it
  • Roper Master
  • 4,289 Answers
2 Suggested Answers
SOURCE:
  • 23 Answers
SOURCE: My Roper washing machine keeps filling and draining in the final rinse cycle.The lid lock light flashes and the machine will not complete the wash cycle, just keeps filling, spinning and draining!
Depending on your model, it will either have an electronic or mechanical timer. If electronic which it sounds like, you likely have a bad board or control unit. If mechanical you will need a new timer.
My old washer was mechanical and I had to replace the timer several times over 18 years. My new Samsung is all digital so when it goes bad, will have to diagnose the circuit that needs replacing. Normally there is an error code on the LCD readout.
Posted on Mar 20, 2016
Mar 20, 2016 | Roper Washing Machines
Locked. How can I unlock?
Search Results
    Lid locked & will not unlock - MVWC400XW2 - YouTube
    ? 2:12
    www.youtube.com/watch?v=Lxs5ga4u_pw
    Sep 18, 2013 - Uploaded by ApplianceVideo.com
    ... Washer suffering from this following problems: Lid Will Notunlock At: ... Whirlpool & Roper Washer Diagnostic - Lid locked& will not unlock - ...
Sep 30, 2015 | Roper Washing Machines
Kenmore Elite Oasis HE Washer #27087. Doing a load of wash & wash & lock lid were flashing. Could not unlock lid & panel kept flashing. Unplugged cord for 30 minutes. When I plugged back in...
I would think the lid would unlock once you unplugged the machine. Check your owner's manual for any kind of "emergency reset" procedure. Perhaps the lock mechanism is jammed. Have you tried pressing on the lid or tapping it to see if that frees the lock?
Nov 18, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Having trouble with my whirlpool cabrio . . . showing "DU" . . .
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa!
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a du code that will not go off and the door is locked.
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer says du and it wont come on! the door lock keeps clicking like its tring to lock but cant
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
If it is a cabrio:
Sep 16, 2010 | Whirlpool Washing Machines
Du f flashes as code on whirlpooll whasher??
Door Unlock Error
If it is a cabrio:
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
DU is flashing and when I press the Pause/Cancel button this does not clear the problem
Door Unlock Error
If it is a cabrio:
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
202 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Gerry Harvey
Gerry Harvey
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
