Back to:
Tags:
Microsoft Xbox 360 Console
XBOX 360 no video with sound after playing HALO 3 (by 8 users)
posted by mando369 on Nov 25, 2007
When i was playing halo 3 online my t.v. screen turn to a green tint color and the graphic were greenish too but you could still see. So I turn it off when i turn it back on the screen was black with really small dot it lines running cross the screen, but i could still hear the sound on my T.V. I try everything like unpluging the A/V, and switching T.V.s but nothing work. The only thing i want to know what is the real problem. Is it when i play halo 3 that screw up my 360 or something else. Thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
7 Other Users Have The Same Problem
Comment by dank1974, posted on Apr 16, 2008
same problem while playing halo3, screen gets skewed with green and blue. then when I reboot I get no picture and no sound but the xbox works ( freinds can see I am online). thought it was the cable so I replaced it but get the same problem after playing for about 10 minutes. what is the towel trick?
Comment by Guest, posted on Dec 24, 2007
unplayable disc.
Comment by Sirlance69, posted on Nov 27, 2007
While playing Smackdown Vs Raw it went black with sound. I tried the towel trick and I got the 360 to work for a day. Now every other day when i want to play I have to over heat the machine then restart it and it works for the next 24. I am putting mine in the shop and enjoy my problem free WII for a while.
Comment by Sully36, posted on Nov 27, 2007
Same except mine went to a blue screen and I couldn't see anything, and now my TV acts as though there is no input.
Comment by Guest, posted on Nov 27, 2007
Same Problem
Best Solution
posted on Jan 11, 2008
FixYa! (100)
sack234733
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
There is no problem with the TV, input, output or the game. There is something fundamentally wrong with the hardware. I also had this happen directly after the towel trick. There seems to be a direct correlation between the two.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on XBOX 360 no video with sound after playing HALO 3:
I don't want to Accept this solution
Solution #2
posted on Dec 12, 2007
FixYa! (100)
ctf1800
Rank:Guru Guru
Rating: 85%, 3430 votes
http://forums.xbox-scene.com/index.php?showtopic=625804
Thank You!
Solution #3
Thanks for Trying (70)
chilibball
Rank:Wiz Wiz
Rating: 81%, 64 votes
This has happened to me also. I realized that i had put the wrong component cable in the wrong slot. Try moving them around and putting them in the right ports or just use HDMI.
Thank You!
Can you Help with these Video Game Consoles problems?
okay i put in a game and it will take me to a screen that...
The Xbox 360 dvd bookmarking feature doesn't work for me....
When I reached the playoffs in franchise mode the game...
cannot et signed in on line
return shipment tracking
7 Other Users Have The Same Problem - Continued
Comment by controler7, posted on Nov 25, 2007
While playing halo 3 online, the T.V. screen turned to a green color and the graphics were greenish too but you could still see. I turned it off and when I turned it back on the screen was black with really small lines running cross the screen, but I could still hear the sound. I tried everything like unpluging the A/V, and switching T.V.s, changing hard drives, nothing works. Is there a video card that goes bad? Is it a CD lens reading problem?
Comment by aerostal, posted on Nov 25, 2007
same problem but it was halo 2 same symtums and everything did you get it fixed?
Loading problems.
Repair Service
Find Video Game Console Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
