Question about Panasonic SC-HT730 System
Panasonic saht730 getting error code dvdho2 what does that mean?
Unit has been moved frequently in the past several months, but had zero problems until recently. Brand new discs (DVD or CD) started skipping then froze completely. Any selection now attempts reading, but then error message pops up, followed by STOP then DVD H02.
  • 158 Answers
REPLACE THE SPINDLE MOTOR
Posted on Aug 03, 2009
Atikinastarli: I had the same problem (error DVD H02). I took the following steps:
- found problem description in page 37 of the Panasonic SA HTT30 manual at http://service.us.panasonic.com/OPERMANPDF/SAHT730.PDF
- turned off and on (did not solve it)
- changed batteries of remote (did not solve it)
- carefuly removed dust from CD-DVD tray
- the last thing I had watched was a DVD made in Brazil, took it out, pressed shift+CD mode in remote
- put an audio CD that I know is high quality
- suddenly, it worked... not sure which of my steps made it happen; maybe a combination of all of them.
GOOD LUCK!
Posted on Oct 17, 2009
How can I correct F61 error?
See page 37 of the user manual.
Get from lil given here.
Error F61
Check and correct the speaker cord connections. If this does not fix the problem, there is a power supply problem. Consult the dealer.
Feb 01, 2016 | Panasonic SC-HT730 System
Error code U81 onDMR-EX75EB Unit will not power up, keeps shutting down
I have posted advice on the possible cause behind this error code (as well as other members on FixYa) for this model DVD recorder previously. For you I will re-iterate:
The U81 error code is a common problem
with many Panasonic DVD recorders of the DMR-EX series.
This is one of several error codes generated by the main microprocessor IC in the unit which are tripped by corruption, preventing proper operation and which may require the processor to be reset (where practical) or replaced.
U81 means (in technical terms) 'microprocessor communication malfunction' on the universal asynchronous receiver/transmitter' or 'microprocessor feedback information error'.
This is not something the user should undertake to repair themselves; it should really go to an authorised Panasonic repair centre. The cost depends on the parts used (if available) and the labour, however, it is not unfixable. You can always get a quote on this and a second opinion, then decide for yourself if it is economical or not.
(sometimes unplugging the unit from the power point for up to 30 minutes, then reconnecting resets it completely and clears the error code with no further remedial action required)
Usually when this error occurs, and persists, the unit cannot be reset by the user. In your case, the constant shutdown may also likely be a fault in the switchmode power supply as well as a problem with the microprocessor. It may or may not prove an expensive exercise.
Certainly worth investigating at least.
It's up to you as to what you decide to do from here.
I hope I have shed some light on the subject for you and similar people who have experienced this particular error display.
Apr 03, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I keep getting a C2 11 error code. Unit lights and immediatly goes out showing that error. At other times it operates fine. The problem seems to be occurring more frequently. It has been in service...
that error code means not enough gas.
however, there might be something going on with your venting. it could be sucking exhaust air back into the unit. this will cause the same error code.
if your problem is intermittent, then I would suspect the venting to be the issue.
Aug 22, 2010 | Rheem Paloma Tankless Water Heaters...
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
Im looking for the manual for the sa-ht730 please
hi
kindly download the manual from the below link
rating the service very helpful will be appreciated...
Aug 09, 2009 | Panasonic SC-HT730 System
Kenmore Elite HE5t Error Code F35
we have a kenmore HE2 Plus washer, front loader. been getting F28 code for last several months. usually we can push cancel button, and it clears, unlocks the door, we restart and complete the wash. But now it is locked and we can;t clear it. have even unplugged the machine over night, it still will not reset. any ideas?
May 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
U99
Hi there, this is what Panasonic say.... The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Feb 12, 2008 | Panasonic DMR-ES10 DVD Recorder
Not reading dvds or cds
press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE until innitiliazing appears try several times
Dec 25, 2007 | Panasonic DVD-RV32 DVD Player
Faut F489
This is for code f489 as well as f498 F498 means a problem with flash eprom IC; meaning that unit is unable to read the basic instructions from the eprom IC. Can be cuased by several; may simply be a "bad connection issue" at the eprom Ic or somwhere in the Bus line--defective Ic or corrupted information which may or may not be recovered with a "service recovery" disc.(not an end user procedure) First step; try resoldering Eprom ic being careful not to bridge pins. second would be to take the unit to a AUTHORIZED ONLY repair shop for a firmware or eeprom update. Good Luck
May 24, 2006 | Panasonic PV-D734S DVD Player/VCR
Panasonic SC-HT730 System Logo
694 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
