Soak the reservoir with half vinegar and half water over night. This will clean up calcium and lime deposits. Also, straighten a paper clip and insert in the holes where the steam comes out. For future advances, aleays pour the wster out and let air dry. I keep my lid off of mine when not in use. I just put it in a ziploc bag and attach it to my steam mop.
SOURCE: shark steam mop
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
SOURCE: bissel steam mop - no more steam
You have to open up the cleaner, disconnect the pump from the steam chamber you then have to put it in a vise and remove the brass hose fitting on each end. Clean the springs and chambers but the main thing is a channel that joins the two chambers has to be cleaned out.
John
SOURCE: steam mop does not operate
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
f
SOURCE: Shark Steam Mop: Won't steam
Here
may not be getting steam to the head...
Euro-Pro
Here
Manuals
that you need.
heatman101
SOURCE: Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Here
Euro-Pro
Here
Manuals
that you need.
heatman101
Here
Euro-Pro
Here
Manuals
that you need.
heatman101
