Question about KWorld DVB-S 100 (DVBS100) Video Capture
Receive from satilite dish direct
Pictures stops all the time
I had the same problem i have just upgraded from a p4 system to an athlon 64x2 4200 and this has sorted all of my problems.
Posted on Apr 15, 2008
How do I hook up my satilite dish to our motor home?
Most TVs don't have a built-in satellite receiver. You'll need to buy and install a suitable satellite receiver box for the signals that your dish is capable of receiving. The dish connects to the satellite receiver. Then the sat receiver connects to the TV via either AV cables or HDMI. Hope this helps.
Sep 16, 2014 | Televison & Video
I have a dish 625 receiver and i wanted to know if i could use an rca to hdmi cable to connect receiver to hd tv
You can definitely use an RCA to HDMI converter, though since our 625 receivers do not have HD capability it won't improve the picture at all. If you would like to look into upgrading to HD equipment, you can reach me directly at!
Tommy Faust
DISH Social Media Representative
Dec 05, 2012 | DISH Network ViP 211 DTV Receiver
Smart is not put in right this is message error
joann edwards,
I hope this has been resolved by now, but if now I would be happy to provide assistance! It sounds like the smartcard may need to be updated with our recent G3 model which is purple.
If you can send me an email at with the phone #, I would be happy to check this out further with you!
Tommy Faust
Jul 25, 2012 | DISH Network 322 DTV Receiver
My 311 is connected to a dish 100.2. It has worked fine for a while. A few days ago it lost signal. I ran a swith check and it said there was fewer satilites than normal. Well I checked out the dish and it...
When you get the message 836, found fewer satellites than previously detected, it usually indicates a problem with a component between the dish and receiver. Normally a tech needs to be sent out to find the problem and to fix it.
Depending on the number of receivers you have active on your account, you may have a loose cable to that receiver if other receivers are working okay. If you have a switch between the dish and receiver, a port on the switch may be bad. If this is occurring on all your receivers, you'll need to call Customer Service to setup a Tech visit.
I hope this helps.
Ray Calo
DISH Network
Nov 07, 2010 | DISH Network 311 DTV Receiver
Satilite weak cant pick it up goes to screen agree and touch wont work then says weak satilite
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 02, 2010 | Garmin StreetPilot 2720 GPS Receiver
Can't watch anyother shows while recording another
Check the back of the DVR to make sure BOTH cables from the dish are properly connected to the receiver. Make sure they are properly tightened. It sounds like one of them has come loose, because if the receiver only has one working cable coming in from the dish it can only do one thing at once- you can only record one show at a time with one cable. You can also go into the receiver's setup menu and run a system test, which will help you diagnose the issue.
Feb 08, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Bose remote device code for directv satellite box
im living in st maarten nederlands antillies on the dutchside and i boutgh a sitilite box in newyork i ask the people if that can work in ST.Maarten they said yes but ST.MAARTEN is dish network i cant find the code program for the box that box is direct plus hd dvr directv satilite reciever. please can you help me.
Dec 01, 2008 | Bose 3 2 1 GSX System
Sure you can, if you have Dish Network go to the receiver and turn the TV and receiver on. Then press menu-6-1-1. This takes you to the point dish screen. You will come out with better results using a compass to find the azimuth the dish should be pointed toward and bore sighting the dish by pointing it in that direction. You then will need to move the dish in very minute increments pausing for 15 to 20 seconds after each move to ensure the satellite signal can be found. If you have ran a check switch prior to this and have lost all satellites you more than likely will not receive a signal until you run another check switch and have found the signal of at least one of the orbitals. If this proves to be to tedious and many times it will you can usually find an inexpensive signal pointing device at a store like Radio Shack. Hope this is some assistance to you. Let me know if I can be of additional assistance and thank you for using Fix Ya.
Oct 07, 2008 | Televison & Video
KWorld DVB-S 100 (DVBS100) Video Capture Logo
32 people viewed this question
Top KWorld Televison & Video Experts
Level 1 Expert
Ruben Balisbis
Ruben Balisbis
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
