Question about HP Pavilion a450n PC Desktop
Warning PC entering power save mode
I have an HP a350n. I'm not sure when it started, but before it happened while I was on the computer the graphics on the screen got all distorted. Shortly after that the computer shut itself off and I got the Warning pc entering power save moded. I shut it off and left it alone and tried to start it and it worked, but only for a few minutes. Once I got it to turn on again I went into the control panel and changed all the power save options to never. After that I took the cover off and air cleaned the dust out of the inside and I replaced the battery in it. It still wont turn on. I unplugged everything except the keyboard, mouse and monitor, I unplugged the pc then pushed the power button. I plugged it back it, and still nothing. It sounds like it is doing something and the little yellow light at the bottom flashes, but nothing. It never gives me an opportunity to push f1 or f8. Everyonce in a while I can get it to work, but like i said, not for very long befoer it craps out on me.
  • courtney_bea Aug 01, 2009
    I bought my computer in 2004, so I don't think it is under warranty. How do I know where the graphics card is? I know I have a NVIDIA GeForce 4MX 440 AGP 8X graphics card.
  • Michelle Crabbe May 11, 2010
    Based in the information you have provided it could be a video issue. Since you did air clean the inside of the case, did you check to ensure that the video card was securely in place? You mentioned that the graphics issue was the start of this. Therefore it may be a problem with the graphics card or if you are using the built in video, it may be an issue with the graphics chip on the board. If you are using a video card, see if you can find another to replace it with and try using a new video card with it. You can basically break down the issues by starting with the first issue at hand. I would also check and see if your system is still under warranty and talk to HP prior to doing anything with your system. Let me know if this helps. CK
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 157 Answers
Hello courtney_bea,
There is an article at the forums11.itrc.hp.com site titled "HP a350n not powering up". The person submitting the post learns, with the help of forum members, that his problem was a bad power supply unit. If you read this article, it may give you an idea or two about the HP a350n problem you mention: http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447626+1249164903176+28353475&threadId=1262287
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Posted on Aug 01, 2009
Have hp pavilion a340n that won't start, screen says "WARNING" PC entering power saving mode and then goes blank. the computer never boots up.
hi mylesj880,
Press del. or f8 to boot to Bios there should be an option for you to remove power saving mode. If none then you probably need to update the bios be careful when updating bioses.
Hope it helps. Feel free to ask
Thx
Banaple
Sep 02, 2010 | Computers & Internet
Monitor displays "warning pc entering power saving mode
Hello
Sounds like to power settings were set too low. Restart the PC, before it gets to Windows press F8. This will send the PC into SAFE mode. You'll get a menu of which SAFE mode to select, just select SAFE mode with networking. Once in SAFE mode, go to START, Control Panel, Power Options. From there select new settings. Since this is a desktop, I would make the settings very long. Good luck
Mar 03, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
The pc entering in pwoer saving mode and
  1. Start or restart your computer.
  2. Press the F10 key when the F10=Setup message is displayed.
  3. Select the appropriate Language option.
  4. Select the Power menu.
  5. Select (if not already selected) the Energy Saver item.
  6. Press the Enter key.
  7. Select Advanced .
  8. Press F10 to save the change.
  9. Select Power > Timeouts > Hard Drive Timeout > Never .
  10. Press F10 to save the change.
  11. Select the Power > Energy Saver .
  12. Press the Enter key.
  13. Restore the desired Energy Saver Mode (Disable or Minimal).
  14. Press F10 to save the change.
  15. Select File > Save Changes and Exit .
Feb 03, 2010 | HP Compaq d530 PC Desktop
Monitor warning pc enter power saving mode
Are you using usb keyboard and muse. if so your usb ports are dead
Jun 16, 2009 | HP Pavilion a450n PC Desktop
Power saving mode upon start up
i) usually an computer enter's into power saving mode if computer monitor is not receiving any singals from the computer tower, so it has nothing do withur computer monitor(computer monitor is working fine), there is some problem withur computer tower.
ii) now try  removing all the physical connections going to computer tower(back side), wall socket  and replace them ....., (to avoid loose connections)
   now see whether ur computer is turning on and working properly so that your computer monitor receive singals ....
  let me know what is happening
Thanking you
M. Sridhar
Jan 01, 2009 | HP Pavilion a450n PC Desktop
Graphics card removal
Unplug your computer, open the CPU and remove the old graphics card (the one where you attach your monitor cable) and replace with your new graphics card. Handle the card by the edges and avoid touching the sensitive electrical components. Insert it fully to the card slot (a loose video card will prevent your monitor from working). Once the computer prompts you that you need the driver for it, just insert the CD that comes with the model of your new graphics card and follow the directions.
Sep 24, 2008 | HP Pavilion a350n PC Desktop
HP a350n not powering up.
unplug power and open computer and pull the small battery and wait 30 sec and replace
plug in everything and reboot
may have to re-enter cmos utility
Aug 24, 2008 | HP Pavilion a350n PC Desktop
WARNING: PC ENTERING POWER SAVING MODE
sounds like a faulty power supply unit
Mar 24, 2008 | HP Pavilion a450n PC Desktop
Pc entering power save mode
I am having the same problem . The system is starting up and th epc entering power save mode. I have a Hp pavilion f1503 model monitor. I hit the power off button on the power surge to shut the entire power off. I turn the power surge button back on. Sometimes it works. Or have to hit the power on button to reboot.
Dec 12, 2007 | HP Pavilion a810n (PP164AA) PC Desktop
HP Pavilion a450n PC Desktop Logo
271 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
