Question about Microsoft Xbox 360 Console
XBOX 360 Power Adapter
I plugged my XBox into 220 Volts. I now have no power to the XBox. Can I just buy the power adapter or is the whole box damaged?
    Problem Solver:
Is it an american console or european. also if it an usa console you will need a voltage converter
Posted on Apr 17, 2008
  • 79 Answers
What happened when you switched on the console? I think the 360 is supposed to run from 240v (at least that's what it says on the power brick) 220v may not be enough to power the console. You may have damaged the console but I'm unsure as I've never run into this situation before. You could try another power brick making sure you use the correct voltage. I'm sorry if this isn't much help but please rate if at all useful, thanks!
Posted on Nov 25, 2007
Power adapter
When your power adapter blinks orange, it means that it is only getting around half of the power it should be getting.
Make sure all of your plugs are plugged in correctly.
If it still blinks orange, I recommend contacting Microsoft, since it could be a loose wire/cord or a hardware malfunction.
Buying a new one works also.
Mar 15, 2014 | Microsoft Kinect Power Adapter for XBOX...
Power adapter for xbox360 is flashing orange
When the power adapter flashes orange, it usually means your console/adapter is only getting half the power it should be getting.
Check all your plugs and make sure everything is plugged in correctly.
If your console isn't turning on, contact Microsoft suppport or buy a new power adapter. If it is turning on, there is no need to do anything.
My Microsoft Xbox 360 Pro's power brick wont turn
You can try to Reset the AC adapter by following steps below.
1. Unplug the xbox 360 AC adapter at both ends (from the back of the system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
If this doesn't work it's probably fried from the power surge.
Jul 31, 2012 | Microsoft Xbox 360 Console
Xbox adaptor burns by over voltage
You should buy a new power adapter of 220V. Your Xbox should be safe. I faced similar situation when I pulgged my xbox in India and this was resolved by buying a new power adapter.
Dec 06, 2011 | Microsoft Wireless Network Adapter Xbox...
Hi my name is sahib i have recently bought an xbox 360 from canada i take it to india i get a volt adapter 220-110 it played game nic but after a week when i was playing game on it a sudden spark come ...
The best option for you would be to take it to a repair shop and see what's exactly wrong with it. Find out what it would cost.
In the case that you have to buy a new one, buy it refurbished. It should save you some money
Mar 02, 2011 | Microsoft Xbox 360 Console
No power, ac adapter was plug to 220v... pls help me
Did you mean that the ac adapter was a 120 volt and was plugged to 220 volts. ? If so the adaptor has failed int he power supply and must be checked. Please clarify.
Jan 24, 2011 | Microsoft Xbox 360 Console
Hello were can i buy a power cable for my xbox 360
Amazon or eBay. Make sure that you get the power adapter and the power brick. The power adapter is the part that connects to the wall, it then connects to the power brick, which connects to the Xbox.
Feb 22, 2010 | Microsoft Xbox 360 Console
I play for +- 30 min and the powersupply goes on red is it the powersupply or the box
If you are getting a red light on the Xbox 360 power brick, That happens when the power supply gets to hot or its not getting enough juice. Try plugging it in somewhere else and see if that helps, and make sure not to use any UPS, surge protectors or power strips to plug in your AC adapter
also check if the power connector is firmly connected or not behind your xbox 360, if you still have a problem, check if you can borrow another Xbox 360 from anyone you know and swap the adapter and console which would help you know where the problem is
If none of this works, call up Microsoft for further help and support, since your problem may require servicing of your console.
If you are getting a Red Ring of light on the Xbox 360 power button, please clarify since it requires separate diagnostics.
Hope you get back to gaming on your Xbox 360 ASAP
Dec 01, 2009 | Microsoft Xbox 360 Console
Can i use an Xbox 360 bought in USA in India - given the voltage conversion required? would there be any seperate adaptor available for 220 volt usage in India
You can purchase a volt adapter (rather common in travel stores/airports) but over time the device's power-supply will wear out because of the frequency difference.
North America runs at 60hz
India runs at 50hz
Jun 30, 2009 | Microsoft Xbox 360 Console
X box 360 wireless adapter
go to look at theyre adapters for the xbox they say it works for $45.00
Jan 02, 2009 | Microsoft Wireless Network Adapter Xbox...
Microsoft Xbox 360 Console Logo
373 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
