Question about Dryers
Need to get into dryer to check heating element unit does not heat up all else seems ok model no. MDE9316AYW 5600 watts...help rubenandyolie
    Brigadier General:
  • 4,088 Answers
Check the house electrical panel dryer breakers (pair), push OFF, then ON. If breakers trip again, problem is a short inside the dryer. Pull the power plug from the socket. The top must be opened which allows access to front panel screws from inside. Lift the panel and pull away from cabinet. Disconnect the wiring to door switch and light. Make a diagram of wiring colors and where they went. Uncouple the drive belt from the motor--go through a sub-panel in the back and release a large tension spring from the idler pulley, then remove belt from motor. Remove several screws from inside of drum center, then lift the drum from the case. The heating element(s) are mounted in back of the drum on a supporting wall. Look for any burned areas or wires that touch the surrounding metal. On reassembly, check the condition of the drum belt--any cracks or missing pieces--replace the belt now.
Posted on Aug 01, 2009
Lgdle2516w spins but no heat
That's an electric. Sounds like one of the two circuit breakers has popped. They should be tied together. Check breaker box.
I think the unit is too new to need a new heating element. Could be wiring to the element. There normally around 5600 w. and run on 220 v.
Apr 13, 2014 | Dryers
Dryer won't start
have you left the unit unplugged for one night and tried to start??
doe sit make any humming noise when trying to start
Aug 25, 2008 | Frigidaire GLEQ642A Electric Dryer
It tumbles and or runs but no heat is produced help with the location of the element 5600 watts
The element is 2nd, 3rd, or 4th on the list of things to check. Most of the more modern dryers have a thermal fuse and some have 2. Use an Ohm Meter and check them for continuity first. Then check the heating element. When you ask these questions always give the Brand name and model number.
Oct 01, 2011 | Dryers
Dryer works fine except it does not seem to heat properly. Wondering how the element is installed and where I could find replacement heating element.
I would need a model number to look up your heating element.
I can tell you that chances are if the dryer heats, but just takes to long to get things dry the heating element is probably ok.
Poor air flow is what causes dryer to take longer then normal to dry.
You will want to check your vent for restrictions such as kinks or lint build up. Don't forget to check the outside hood as it has a flapper or even a screen that can catch lint.
If your vent is ok then you need to take the dryer apart and check for lint build up around the blower housing and fan.
Aug 02, 2011 | Dryers
My ge gew9250p dryer heating element is needing replacement what is a good part number for this
Hello there:
this should help you out ok
See Part # 14 on diagram.
or
See all parts for this section / diagram Heating Element (11" long x 5" wide) (Heater Element) This heating element fits later model Whirlpool/Kenmore brand electric clothes dryers. Each of its two terminals measures 5/16 of an inch, while the unit itself is approximately 11 inches long by 5 inches wide. This element carries 5200 watts and 240 volts. Appliance Help Part Number AH344597 Availability: In Stock Compare At: $56.32 Your Sale Price: $46.93 You Save: $9.39 SALE PRICE:$46.93 -->
Nov 22, 2009 | Whirlpool GEW9250P Electric Dryer
Dryer does not heat up.
Hello there:
normally on these units if the dryer was working ok and then suyddenly stopped heating your heating element or the ignitor (excitor ) has failed and is need of replacement
so i would start by having these things checked first by contacting a local repair man to do a evaluation on the unit and if kyou still have a valid warranty i would use it ok
I hope that this is very helpful for you
Best regards Richard
Nov 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Tested heater element and all fuses all seem ok ?
i presume your saying "NO-HEAT" condition....check for240volts at input to unit,then it could be a burned off neutral wire to the element,it NEEDS the neutral to make the element heat,then the limit switches could be faulty
Aug 06, 2009 | Candy CDC266 Dryer
Wont heat up
Hi. if this dryer is an electric unit, you will need to check the thermal fuse. if this fuse is busted, simply replace this fuse with a time delay version. Once you have replaced it and it seems to blow once more, this will signal a more serious issue with the element that is involved with the heating process. With a multimeter, check the element for continuity by using the element terminals for testing. connect the meter to the terminals located on the element and select a cycle and hit start. once you have hit the start button, there should be a reading that will show up on the meter. if there is no reading, there may be an issue with the wire harnesses and connectors or, the timer may be bad. In this case replace if needed(wire harness or timer/control). Ok, if the meter picks up a good amount of current and, the element isn't glowing red, this will confirm a failed element. (replace the element.
GAS
If this unit is a gas dryer, make sure the thermal fuse is working here as well. if the fuse is ok, simple, check all exhaust hoses for blockages and remove all lint from the internal traps. if the unit still doesn't heat well or not at all, simple, replace the coil assembly. this will fix the heating issue in this type of unit.
Please rate and god bless:)
Apr 02, 2009 | Dryers
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Dryers Logo
135 people viewed this question
Top Dryers Experts
