Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Power will not come on, some kind of timer seems to be in place,
Power to house went off and on. No problem til thunderstorms, now the power button on set doesnt' do anything. The power from the remote will flicker green but nothing comes on. I am at ronji@aol.com
    Problem Solver:
  • 11 Answers
Damage or destruction caused by transient voltages and surge currents are in fact covered by your home insurance as long as you can get from your utility supplier confirmation of an out surge caused by this storm. This is a solution to your problem as often damage caused by an electrical storm is such, it is not worth trying to repair it. Damage to switched mode PSU and logic circuits renders the TV beyond economical repair.
Posted on Sep 12, 2009
    Brigadier General:
  • 4,090 Answers
Claim fusion on your insurance policy but dont mention lightning as its an act of God and not claimable in many instances
Posted on Aug 01, 2009
Just stopped working. No burning smell. When start button pushed, some kind of tiny "click" sound heard around the timer.
The click is most likely the timer motor moving the dial on the timer. The motor circuit on American dryers is 120 volts whilst the heater requires 240 volts to operate its 5k element. The motor circuit always has the fuse in it. The heating element has limits mounted on it but they only kill power to the element and not the motor. Fuses are usually located on the blower housing next to the control thermostat. MORE HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 29, 2012 | Dryers
Hi. We're having power outages in TX right now. When power in house came back on, our Philips Home Theatre System (HTS 3544) seems to have lost all its power. We've plugged and unplugged the unit, and...
These are prone to power spikes...and for that reason have a fuse located on the power supply board...known as fast blow fuses...which are glass and easy to see if they have blown..sometimes all you need to do is replace the fuse on the rear of the unit if you can locate a fuse cap...just unscrew and replace....Always unplug televisions and audio equipment and routers during power outages and thunderstorms as a preventative to blowing psu panels on electrical devices connection to your house mains for this reason .
Feb 05, 2018 | Philips HTS3544/37 Theater System
It's my mothers and she had a power surge during a thunderstorm in Tulsa, ok. The power in the whole house flickered off then on again. the TV was on...went off with everything else (no surge...
I have seen a few cases when all that is necessary to repair would be to replace the power fuse. In worst cases transistors and resistors will be blown. You will have to find a TV tech to inspect the power supply. Give me a few hands and thanks for asking!
Sep 13, 2010 | Televison & Video
My cable went out during a thunderstorm. The
if it is new it should be under warranty,if not ,yes there may be a fuse inside,on the board where the plug is connected,taking it apart will void the warranty and can be dangerous .dont try this unless you have experience
Sep 21, 2009 | Televison & Video
Light comes on but refrigerator and freezer are not cooling. this happened after a thunderstorm shut off house power over the weekend.
I don't know what brand, how old, what the model is but if only the light works, you could be looking a shorted defrost board or def timer, burn't wire somewhere, or toasted start relay/overload on the compressor. The cold control may also be shorted. Just not enough info, sorry.
May 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Can a tv ordvd player be fixed after going dead after a thunderstorm
Not usually. If the thunderstorm damaged it, there is most likely all kinds of burnt circuits. Most warranties don't cover that kind of damag either, unless it was plugged into a power strip of some kind that has a gaurrantee against damage.
Jul 10, 2008 | Televison & Video
TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Flashing On Timer
This is usually an indication for a scan failure, and or high voltage failure. Also, the power supply may be damaged.
Depending on the nature of the failure, this type of service can be sort of expensive. I sugget to get an estimate before deciding.
Jerry G.
Jun 11, 2008 | JVC AV-27D302 27" TV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
152 people viewed this question
Jerry Greenberg
Jerry Greenberg
