Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
The outside cabinet skin is 114 deg. Is this normal? What is the poroblem? The inside tem.is 14 deg. Is this normal?
  • Kenmore Master
  • 3,361 Answers
Yes.
Posted on Oct 04, 2009
Freezer freezes up on outside
This problem sounds like the door seals have either perished or broken somewhere. Check that the seals along the outside edge of the inside of the doors are intact and not damaged in any way. Any gaps or crushed parts may result in cold spots on the outside of freezer. There may even be a foreign object between the cabinet and the door seal, if so remove.
Dec 04, 2014 | Freezers
Defroster
It should be under the evaporator on top of the unit. There should be an access door that you can remove to get to. It might be inside The cabinet or on the outside depending on the model number that should be located on a tag on the wall inside the cabinet. This will be the number you need for replacement parts as they change a lot. wright down the model number and serial when you get the part.
Aug 27, 2014 | Everest Refrigeration ESRF2 Reach-In...
Looking for condenser sears freezer Model 25326432100
If you can't see a radiator looking grille, the condenser is in the skin of the freezer. Does the outside get hot? Does the pipework come out of the compressor into the outside skin of the freezer?
Apr 13, 2012 | Kenmore Freezers
Bought an upright Frigidaire Freezer on Craigslist and the inside gets cold and works like a champ but the outside side panels get very hot- is this normal or is there a short?
If there is a short circuit, the circuit breaker protection in your house wiring would trip (Open the electrical circuit path).
It is normal for the condenser, which is on the outside of the appliance to be hot because it is transfering the heat from inside the freezer cabinet to the ambient air outside the cabinet. Make sure that you give the appliance enough space all around the hot condenser so that it can transfer its heat to the surrounding air efficiently.
P.S. Some freezer designs integrate the condenser coils into the metal cabinet, thus the hot side panels.
Aug 28, 2011 | Frigidaire 14 cu. ft. / 396 liter Upright...
The outside of the freezer sides are extremely hot to the touch? Why? Freezing fine on the inside.
the coil normally on b ack of fridges is on sides of freezers under skin it is normal to be warm. The hotter the weather the hotter the skin.
Sep 02, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Red light is on on bottom panel and buzzer is going off. Inside temp is 20 degrees and outside temp is 25 deg
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Not all refrigerators are insulated the same and not all condensers are in the same place. Your cold control is monitoring the temperature of the refrigerator section and is designed to turn off the compressor to keep things from freezing in that section. If it stays cold long enough outside in your garage the cold control thinks its cold enough and won't turn the compressor on. A makeshift closet to hold a little heat the unit generates will probably help.
Jan 06, 2010 | Freezers
My stand up freezer
If your freezer is working normally then this problem is normal condition as the condensor coils are behind the cabinet sides to radiate heat keep good ventelation around the cabinet
Jul 26, 2009 | Kenmore Freezers
Freezer gets cold but doesn't freeze
check tem.p inside cabinet and let us know what you find
Jun 29, 2009 | GE Freezers
Normal operating pressures
Normal operating pressures will change as the freezer reaches the selected temperatures on the inside. Normals of minus 14 degrees on the inside would be around minus 4 psi on the suction and 150 pis on discharge. Now checking the pressure will require a set of guages that have been purged with the same freon before connecting with the suction line on freezer. If not purged the suction line will draw outside air into the system and cause freezing of air and moisture inside the capillary tube rendering the freezer inoperative, Hope this helps, Sea Breeze
Nov 01, 2007 | Freezers
Leakage and warm sides
The outsides should will be warm.  This is normal because the condensor lines run thru the cabinet from about half way up the sides and over the top.  Which is why the you shouldn't have anything stacked on top of the freezer and enough room on the sides of it for air flow.  As far as the water leak, tell me exactly where you see the water and does the bottom of the freezer (inside) have a sheet of ice on it.  If there is ice there then the drain behind the bottom panel in the freezer is frozen over and will have to be thawed out.  Let me know what you find.  If you have further questions I may need the entire model # on the sticker inside the freezer.
Oct 21, 2007 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Freezers Logo
100 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
