Dave Moir Posted on Jun 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot print glossy a4 epson prints from epson dx 8400 printer. help!
Brett Duxbury
Level 3:
  • Epson Master 4,352 Answers
  • Posted on Jun 04, 2018
Brett Duxbury
Epson Master
Level 3:
Answers
4352
Questions
0
Helped
1118693
Points
13423
What paper are you using ?
is it glossy a4 photo paper designed for an inkjet printer ?
see
https://www.officeworks.com.au/shop/officeworks/c/paper/photo-paper/glossy-photo-paper
for an example of this special paper
5 Related Answers
Anonymous
  • 2072 Answers
  • Posted on Mar 28, 2008
SOURCE: DX stylus 4050
CLick on this site
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes
Download the proper driver to your desktop, when the install asks you for a driver location, click bworse and select the driver and do an auto install.
Should be quick and fairly easy.
aicaxz
Anjazmoro Wicaksono
  • 511 Answers
  • Posted on Jun 10, 2009
SOURCE: Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Anonymous
  • Posted on Aug 17, 2009
SOURCE: not printing glossy A4 paper / paper jam / no paper feed
dont use thick photo paper like 230 gsm up, instead use 180 gsm papers. but if you dont want to waste the purchased thick photo papers, you can open the back and manually insert the paper once the printing process started. i tried this as a trial & error basis until i had perfected it.... hope it works with yours.
Anonymous
  • 2185 Answers
  • Posted on Sep 20, 2009
SOURCE: Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Testimonial: "tried blowing and dusting with a brush Now it comes on as normal - no flashing light but will only take paper about 2 cms then flashes paperjam"
Anonymous
  • Posted on Nov 14, 2010
SOURCE: Epson Photo PX710W Unable to print
Im having the same problem, will print on normal paper but when I try to print onto Glossy paper it comes up with paper jam,or paper not loaded properly is anyone else hjaving this problem? Please help!!
Caroline.
All ink cartridges full but wont print black, dx 8400, please help
try to perform a head cleaning process for a few cycles then try to print again... this may also depend on how long was the printer been stored for it to have clogged nozzles
1helpful
Glossy A4 paper will not feed. Is it too heavy?
Actually, if printer is new, printer can feed up to 350 grm. But if pick up rubber at paper feeder mechanics had distort/loose thickness, it can't. Try to use 210 gsm glossy paper. Or, if you wish to use 280 gsm, pull down paper while printer grab paper.
Epson cx 8400
Start, Click Printers & Faxes. Right Click EPSON CX 8400.. Find & Click Printing Preferences. Select the Paper Size (Choose what printing size you want). GOOD LUCK!
Pls! Don't forget to rate me.
2helpful
2answers
I've got the Epson Stylus DX 8400 printer. when I put the cartridge,this message come up: "ink cartridges cannot be recognized." txs
I had the same problem too.  I went to the Epson website and they gave instructions to shake the cartridge 4-5 times prior to installing.   It worked!!!  I tried alot of things before I saw that I needed to shake the cartridge.  Definitely give this a try if you haven't already.
Kodak 5300 wont print on glossy side of photo paper
I just sussed this issue out. On the front of the printer tray there is another pull out tray, this opens up and must activate the photo printing for A4 because it stops the paper falling on the floor once printed (cos once printed on photo paper it may still be wet). As soon as I opened the tray (and it then opens again - you'll see what I mean) it printed A4 photo paper perfectly
Hope this helps others
Epson R300 printing only in top left corner of page
Change the paper settings in the driver when you go to print. If you have it set to 10x15 it will only print a 10x15 patch in the corner.
Go to START, PRINTERS AND FAXES then right click on R300 and select PROPERTIES. Click PRINTING PREFERENCES and set the correct paper properties. Click OK all the way to desk top and the settings will be saved.
On the printer panel press ADVANCED, scroll down 3 times to PAPER SIZE and press OK. Select A4 and press OK.
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
