Question about Whirlpool Washing Machines
Whirlpool LSB6500PW2 Washer have to slam lid to agitate
I have a whirlpool LSB6500PW2 Washer and the problem is my machine is not running and it is filled with water in the tub of the machine. I used to have to slam the lid in order to get it to agitate and continue on with the cycle. I am suspecting it is a lid switch problem and if it is I was wondering how to take the lid off of the machine in order to install the lid switch
Thanks
  • 1 more comment
  • David Szeto Aug 01, 2009
    When you mean swing up the controls and pop the cabinet clips, which is in the back is that correct? Do I need to remove the base that is connected to the actual lid that opens on the machine? I was unable to access the service pictures would you please post it again.
    When I felt the lid switch from the underside I felt it was loose and dangling
  • Dan Webster
    Dan Webster May 11, 2010
    In order for the tech to service these washers, the washer has been designed for the cabinet to be removed to get to all serviceable parts including the lid switch mechanism. One must swing up the controls and pop the cabinet clips, unplug the lid switch assembly and tip the case forward. The lid switch safety quick disconnect going into the washer harnes has 3 wires. One wire is green ground wire. The other 2 wires can be jumped out to make the washer run, bypassing and overiding the lis safety device. HERE is some service pictures. Does this help? Need cheap parts? More questions? Ask away.
WhIzAtIt
  • 136 Answers
SOURCE: whirlpool ultimate care II stops during cycle
THe most likely cause for this is either the lid switch or the timer itself sticking.
Posted on Sep 14, 2007
SOURCE: Whirlpool Washer making loud noise during agitation. Agitator appears to be very loose
Does anyone have the name or part number of the piece that needed to be replaced that help stop makes all that noise?
Posted on Sep 09, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool LSB6300PW2 Won't Agitate or Spin
if you lift andclose the lid do you hear "clicking" noise??? i bet not. simple repair, lift the lid and with a hollow shafted screwdriver(1/4in nutdriver or similliar hollow shaft implement)you fell with your hand the bottom half of the left side lid hinge. as you open and close the lid you can fell the opposing end of hinge under the top no need to dissasemble you can fell it right there. when you find it simply slip the hollow ended shaft over the hinge and apply pressure towardds the rear of unit.While doing this the top will want to close( your pushing against the hinge).. after appling slight pressure youll bend it slightly, enough to activet the lid switch mounted to the rear of the main lid assy.
Posted on Nov 13, 2008
  • 3 Answers
SOURCE: My Estate Whirlpool Washer, model #TAWS850PQ0
if it cuts off the water ok and motor running
it could be a coupling .
possible transmission.
if no motor noise
could be motor .
wiring,
timer.
Posted on Jun 16, 2009
  • 23 Answers
SOURCE: my washer wnot agitate unless i slam lid
is the lid up during the filling process? the new washers will not agitate unless the lid is down. no need to slam the lid.. There is no pin to push the activator switch.. they are controlled with a magnet...
Posted on Jul 31, 2009
Water run in tub when washer is off and leaks all over, this is a built in whirlpool dishwasher
If it's clean water the fill valve is bad turn water supplies off see if leak stops. Is it still leaked with water supply turned off check drain hose could be to low causing drain water to back fill into tub
Mar 30, 2016 | Washing Machines
When I turn the washer on the water runs on floor istead of filling tub
the hose which is conected from the water cellunoid to the wash tub is badly damaged and therefore leaking
Feb 20, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool washer - tub drains while it fills.
Your drain is to low. Make sure that the drain that your discharge hose is going into is at least as high as the washer. If not the water will drain out as fast as you can fill it.
Aug 15, 2009 | Whirlpool Washing Machines
The water just runs in my roper whirlpool washer and never fills up and wash the clothes
It sounds like the drain hose may be below the tub level. This will syphon the water out before it ever fills up enough to turn off. The drain hose should go into the plumbing drain at a height above the top level of the tub. Hope this helps!
May 18, 2009 | Whirlpool Washing Machines
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool Calypso Washer: No water fill intermittent
Check the hose from the tub to the pressure switch, make sure its clear and the reservoir on the tub is clean.
Oct 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Water runs, but tub does not fill on whirlpool washer
Well...if the water is running, the tub is not filling, and you don't have water all over the floor, your drain hose is installed too deep in the drain pipe, or just installed too low, so that the water is simply running out of the machine and out the drain hose.
Sep 14, 2008 | Washing Machines
Whirlpool top load washer- tub will not keep balance
did you take out the shipping bolts when you bought it if you did then its the universal joint under the agitatot or in it more likely
Dec 29, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
270 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
