Question about Garden
The spring for the pto brake came of and I'm not sure where it goes. I see a hole on the brake arm, but not sure where the other end attaches. this is on a cub cadet model 3100 tractor/mower.
    Champion:
  • 363 Answers
I assume that the brake return spring would be attached up under the control panel since the spring has to offer resistance against the brke peddle
Posted on Aug 02, 2009
My PTO cable with the spring on the end came off. I'm trying to reconnect the spring from the PTO cable but I have no idea where to connect it too. Please help!
Not sure what PTO cable you are talking about but if you are referring to your manual deck engagement lever with a cable and spring I may be able to help..This happened to a friend of mine..what you are going to do is lower the deck as far as possible and get the mower off the ground so you can early see the operation..then have a friend work the manual lever back and forth while you kids hold the cable towards the deck..this will,give you and idea about where it should be attached...the using a bright light look for some shiny area where the spring or cable would have been attached and wearing the paint off...Note. The spring and cable pull an idler wheel or spindle on the deck to engage the moving belt to make it mow, try locating that and move it by hand...it should have an attachment or holes, look closely possibly it did not just come off the end may be broken...good luck..
Jun 24, 2015 | Garden
How do I reattach the deck to my riding lawn mower
do you have a pto lever that tightens the belt? if so theres a bracket on top and in the back that holds the cabble but first you must attach the spring to the pulley that's on a arm that releases and tightens the belt, there is a hole on the arm closer to the pulley itself hook that up and pull with a little strength and put the end of the plastic of the cable in that bracket and with a carter key holds it in position and then try your lever then make sure nothing is rubbing or under a strain, hope this give you some idea of what to do
May 16, 2015 | Garden
I have a MTD yardman 1999,2000 ride mower that won't start because it says the pto is engaged when it's not actually engaged if you could comment an image of the same 42 inch deck?
Check your PTO switch operation which is at the engagement handle.
As for hooking the cable spring to deck idler pulley and brake assembly it goes in the hole closest to the idler pulley on the G deck which different then the F deck which uses the same idler arm assembly as the part is design to fit both decks.
Also make sure your using an OEM spec as a will fit will not work properly. You also must the spindle pulleys belt retainer covers in place so the belt will stay on.
May 10, 2015 | Mtd Garden
On a 89 Mazda B2200, where does the spring for the self adjuster connect?
sounds like a brake question.....what spring? where? 89 is getting up there friend......think "change"
Feb 12, 2015 | Mazda Cars & Trucks
Toro LX468- Was replacing belt and a small (2") spring came loose from I think the PTO ? Also the PTO clutch should be in what position to permit belt guard installation? Does the guard go into the gr
Yess it goes into the groove to prevent clutch housing from turning and the position of the housing when install the retaining bolts.
The spring into the hole on the clutch housing and other end goes somewhere on the frame. It is being used as a damper spring.
The below should be correct.
Oct 23, 2014 | Toro Garden
John Deere A120 tension spring for PTO broke off and flew across yard I have the new spring can't fig out where it goes HELP>>>>
find the pulley that is loose and rotate it until the belt is tight either way, then add 2 inches on to the spring length and you should find your hole. remove belt from largest pulley that is clear and insert spring through hole and attach other end using a no 3 screw driver using slot to guide spring end into hole.
Nov 04, 2013 | John Deere Garden
Pic/diagram of 10hp briggs & stratton governor,model 205412
on the governor arm itself,,,,there are a bunch of little holes drilled into the arm ,,,one end of the spring goes into usually the third hole from the shaft that the arm is hooked to,,another words the third hole away from the shaft,,,,then the other end of the spring goes to a stationary point to create a stationary base to the end of the spring for constant pressure..usually there is a deal sticking up for the spring to allow maximum movement of the spring without it touching anything.,,,hope it works,,,trial and error in this case is the best thing ,,hook it up WITHOUT stretching it too far,,if you stretch the spring to far then you WILL have to replace the spring!! be carefull on stretching it.
Nov 28, 2011 | Briggs & Stratton Power Products 5,550...
Where does the blade brake spring attach on an MTD 42 inch deck with manual PTO? One end connects to the blade brake pivot arm, but the manual is unclear as to where the anchor point is.
the other end goes on the pulley engagement swingarm so when you turn the blades on the spring pulls the blade brake away from the blade pulley so the blade can turn. hope this helps
Sep 13, 2009 | Mtd Garden
Carb linkage hook up
Hello rebel_auto:
>>Send me the Make, Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you.
However, this File may Help.
**The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and the Other End of this Spring Attaches to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Craftsman Garden
Governor spring on a 6 hp briggs intek ohv came off
Hello graham8718:
>>If you Require more Assistance, then
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
