Monitor will work sometimes, with no problems at all.
When turning monitor on, it boots up and then "Analog" appears in a blue box and the screen shuts off with
the power light ltill on. This is an EMachine 19" LCD widescreen onoitor and is only a month or so old.
Does it have a digital port being used? If you are using the DVI port, it is probably digital. Try using the menu to selct the port. If it doesn't work, not sure from here. What is the model number?
I have the same problem --boots up, then analog icon, then screen goes blank and power light turns yellow. The input is via analog cord and connections.
I have a 20 inch screen E machines computer and I am trying to connect my HP four in one printer and...
(More)
I have a 20 inch screen E machines computer and I am trying to connect my HP four in one printer and the computer has a USB cord for the printer but the printer does not have a USB plug. is it campatible??
Specvision 17" tft just has plain mid grey screen. Computer sees and identifies the monitor but...
(More)
Specvision 17" tft just has plain mid grey screen. Computer sees and identifies the monitor but no picture. It's in dual display mode and works fine with my other 2nd monitor. I've tried all adjustments in the Nvidea control panel. I think the monitor is faulty but not sure if this sound fixable to you guys or is it for the tip?
many thanks GB
