Question about Kenmore 44102 Front Load Washer
Noise while spinning. Probably a missing coin and part of an ink pen that are missing but not in the tub.
    Problem Solver:
  • 5 Answers
There is an inner and outer tub it may be trapped in between the two. can usually pull aggitator and remove inner tub to check
Posted on Aug 22, 2009
Why is my washing machine making a noise when spinning the clothes?
you may have to remove the agitator to check for something like a bra wire , coins, bobby pins etc that is stuck in the tub holes and rubbing on the stationary tub when spinning
Sep 28, 2016 | Washing Machines
Rattling noise in spin, spin problems becoming more pronounced. control panel lights flash but 0 error codes. unplug 2 reset, probl repeats
If this noise is happening while it's trying to drain water then you have something floating around in the lump. Coins are very common. If the noise is happening during a spin cycle and more pronounced during the final high spin cycle, you have bearing or spin tub issues. Time to go shopping.
Nov 07, 2013 | Frigidaire ATF6000ES Front Load Washer
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
Their is a loud scraping noise when the washer begins the cycle. I have cleaned out the filters and there was no noticeable lime build up nor debris. The tub spins freely but the noise is persistent. We...
Have you check the pump, all front load washer drain before filling. If you have coins or foreign object inside pump the can be the cause of scraping noise. I would also check the tub for nails or object that can poke through and tub on the outer tub during rotation. Most of the time its a foreign object in the pump issue. Good luck..
Jul 11, 2011 | LG WM0642H Front Load
Noisy drum bearing also play on drum
Apr 30, 2011 | Washing Machines
Makes a noise when in the spin cycle. Almost like coins in the barrel only there are no coins in the barrel. Or sounds like it is trying to change gears and grinds.
Welcome to FixYa.
Based on what you've described, sounds like a worn tub bearing unfortunately.
To check it, remove the agitator assembly inside the tub, once it's off. take the tub assembly and move it side to side to inspect for "play" in the bearing. This will explain the bad sounds and the grinding...I bet it doesn't spin the items out very well either due to too much vibration sensed to maximize spin.
Let me know what you find and I'll try to help you move forward from here. I can provide more detail with pictures if necessary.
Regards,
Macmarkus :)
Mar 12, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Will not drain and stops but does not give an error code.
Check any pump filter and outlet hose for blockages, if all is ok check pump.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Mar 06, 2011 | Maytag Neptune Washer
UBNORMAL SOUND DURING DRY SPIN
Washing machine is noisyIt's very difficult to advise on a noisy washing machine because you often can't describe noises accurately enough. People can describe the same noises quite differently.
Here's a general guide though -
  • If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
  • Coins or other obstructions trapped inside the tub under the drum can make horrendous noises as they get tossed about on spin. They often don't make the noise unless laundry is in though. Look out for obvious dints and creases in the drum itself as evidence of a coin or similar stuck inside although be aware that it only shows there's been an obstruction in at some point and the coin could have fallen into the sump hose or filter and not actually be the cause of the noise at this time
  • Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as the coins get tossed around inside. Often, spinning the drum by hand will not reproduce the noise in the case of coins because the coins drop to the bottom of the tub and lay flat when the washing machine isn't spinning
  • A light scraping or ratchety noise when the drum is turned by hand is commonly a bra wire trapped between the tub and drum. They can often be removed from underneath with the sump hose taken off. It's always worth checking that the wire isn't poking through one of the holes in the drum which can be pulled back out from inside the door. It's rare, but I've retrieved 3 or 4 this way over the years.
  • A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
  • A knocking noise can be a loose tub weight. This would normally be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine. Warning: These days most washing machines have plastic tubs and over tightening a tub weight bolt can easily shear the bracket resulting in a new tub being required. Try loctite. Often, once a tub weight has come loose the plastic tub is damaged anyway especially if it isn't caught early enough
  • Sometimes a badly worn drive belt can cause a surprising amount of noise. I've even come across some where i was convinced the drum bearings were gone until I took off the belt and spun the drum by hand to find no noise.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk. If you have a specific noise you are concerned about, either call an engineer
Apr 11, 2010 | Samsung Washing Machines
It makes a loud noise whilst drum goes round
This is indeed a known issue in LG dryers. Mine does the same thing. Instead of contacting LG, I contacted an LG authorized serviceman. He advised me that replacing the rollers would still make the same noise. The LG techs that he spoke with (these are REAL techs, not the bozos that the consumer talks to) said that the problem can be minimized by selecting the Wrinkle Care option. After the drying cycle is over, Wrinkle Care will tumble the clothes 5 revolutions or so, every 10 minutes. This keeps the rollers round as they are cooling down. It does help, as mine still thumps on start-up, but not for nearly as long. I have come to accept this as a small price to pay for a superb dryer.
Apr 06, 2010 | LG WM-2277HW Front Load Washer
Makes a noise like there are rocks or coins when it spins
If it is thumping... you have a broken spider on the inner stainless steel drum. Major defect with this machine. You'll need to call to get a new washer tub assembly... comes complete with inner stainless steel drum and outer plastic drum already assembled and ready to install. Good luck.!
Jul 01, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore 44102 Front Load Washer Logo
67 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
