Question about Frigidaire Washing Machines
Washing machine will not drain - Frigidaire Washing Machines
  • 6,784 Answers
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Posted on Aug 01, 2009
REPLACE PUMP
easy
  • How to Replace a Washing Machine Water Pump: 12 Steps www.wikihow.com/Replace-a-Washing-Machine-Water-Pump
    • 4 MIN
    • 76K VIEWS
    2016-01-08 · Video embedded · How to Replace a Washing Machine Water Pump. Washing machines are durable and expensive appliances. Repairing them is often less expensive than replacing ...
  • Washer Not Draining? Washer Drain Pump Replacement (Part ... www.youtube.com/watch?v=DwV71h86Gxw
    • BY REPAIRCLINIC.COM
    • 3 MIN
    • 381K VIEWS
    2010-05-14 · This video provides step-by-step instructions for replacing the drain pump on top loading direct drive Whirlpool washing machines. The most ...
  • Geeks On Home: How to Replace a Washing Machine Drain Pump www.geeksonhome.com/how_6509829_replace-washing-machine-drain-pump... How to Replace a Washing Machine Drain Pump. Washing machines take the drudgery out of laundry day, and they're a lot easier than using a washbasin or beating ...
  • Related searches for Washing Machines replace pump
  • How To Replace The Pump in a Washing Machine - YouTube www.youtube.com/watch?v=cvyCSQMPkCc
    • BY BUYSPARES
    • 5 MIN
    • 74K VIEWS
    2011-07-13 · For all your washing machine spare parts and accessories, visit: http://bit.ly/1VKQiNZ If the pump in your washing machine is faulty or broken, ...
  • How to Replace the Pump on a Washing Machine - Bosch ' ... www.espares.co.uk/.../how-to-replace-the-pump-on-a-washing-machine- View All Washing Machine Pumps Now » How to Replace the Pump on a Washing Machine - Bosch. Is your washing machine failing to drain following a wash cycle?
  • How to Replace the Pump on a Whirlpool Washing Machine www.geeksonhome.com/...replace-pump-whirlpool-washing-machine.html How to Replace the Pump on a Whirlpool Washing Machine. The pump in a washing machine helps remove the water from the washer's tub. Water comes in through the ...
  • How to replace a washing machine pump on Aeg, Electrolux ... www.youtube.com/watch?v=yrY9R_T8qrY
    • BY HOW-2-REPAIR.COM
    • 10 MIN
    • 17K VIEWS
    2014-03-26 · How to replace a washing machine pump on Aeg, Electrolux, John Lewis, Zanussi washer dryers Please remember to mark us to your ...
  • How to change and replace a washing machine pump on ... www.how-to-repair.com > Home > Washing machines > Pumps After checking that the pump is faulty in our previous tutorials you will need to replace the old washing machine pump with a new one. Disconnect the appliance from ...
  • Whirlpool Washing Machine Pump Parts from RepairClinic.com www.repairclinic.com/.../a11b5c36/Whirlpool-Washing-Machine-Pump-Parts Shop for your Whirlpool Washing Machine Pump from our huge inventory. Return any part for any reason.
  • How to Replace Beko Washing Machine Pump www.how-to-repair.com > Home > Washing machines > Pumps This video will show you how to replace Beko washing machine pump, If your Beko washing machine is not emptying or draining the water then it is a good chance
  • Mar 10, 2016 | Washing Machines
    Washer does not spin and drain properly
    How To Fix A Washing Machine That Is Not Spinning or ...
    removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
    May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
    Washer Repair - Not draining or spinning ... - YouTube
    ? 5:17
    https://www.youtube.com/watch?v=k41abYwM9WY
    Jul 12, 2013 - Uploaded by ApplianceVideo.com
    Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
    Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
    Holding water
    Good Day,
    Your washing machine is fully automatic?
    the washing cycle is normal?
    if yes do the same maybe it will help you.
    for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
    Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
    if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
    if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
    Nov 02, 2013 | Washing Machines
    Washer won't spin
    Good Day,
    Avanti washer repair
    Good Day,
    Nov 01, 2013 | Washing Machines
    Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
    Good Day,
    Nov 01, 2013 | Whirlpool Cabrio Washing Machines
    Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
    Good Day,
    Nov 01, 2013 | Whirlpool WFC7500VW Washer
    417 44152400 21 code reads e63 and machine not draining properly
    Good Day,
    check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
    Nov 01, 2013 | Kenmore Front Load Washer
    Won't drain and showing F 01
    Good Day,
    Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
    Simpson Aquarius washing machine 7kg: water
    SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
    Jan 08, 2010 | Washing Machines
    Washing Machines Logo
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
