Radio Shack Pro-2018 Scanner
Problem for Radio Shack Pro-2018 Scanner
RS Pro 2020 Scanner won't come out of scan mode, pad ineffective
By amosbanjo on Aug 01, 2009
I use the scanner to monitor water tower level, so it stays on one frequency all the time (never use it to scan). When there is a storm, I unplug it. This time when I plugged it in, it went into scan mode like usual, but the buttons had no effect: Couldn't stop scan to select a channel. Often one can reset some units by unplugging for a minute or so. Even 48 hours. If I turn off the unit, hold PROGRAM and 1,2,4,5,7,or 8, while I turn it on, it beeps and does not scan. Still, no entries can be made from the pad. It is stuck until I turn off/on, when it goes back to scanning. I can do the off/on trick while holding LOCKOUT, where it locks out the lowest channel, but can't unlock. Channel 1 and 2 are locked out now. The battery is dead, so I lost all my memory frequencies (that's OK, I only used one of them). SCAN or MANUAL buttons are supposed to stop the scan, but they don't. Is this thing toast?
Comments:
Aug 01, 2009
- Sorry. This is a duplicate post. Please disregard.
Sep 04, 2009
- TOLHamradio Thanks for the reply. No it is not a Bearcat. It is a Radio Shack Realistic 20 channel UHF?AM?FM Direct Entry Programmable Scanner. It looks like the 2018 except all controls are on the front. I needed a key sequence to reset the processor like the 2018 has, but those indicated for the 2018 don't work. So what I did was hold all the buttons down with my palm and power up. That worked and it's running fine now. I know that's not very orthodox, but whatever works.... I would still like to know the prescribed reset key sequence to write it in the book for future reference. Thanks.
Solution #1
posted on Sep 01, 2009
Somewhat Helpful)
TOLhamRadio
Rank: Wiz
Rating: 78%, 40 votes
If you mean a Bearcat 2020 radio, then that unit is ancient, and I'm amazed that it still works. If you're only monitoring one frequency, you can get a really cheap scanner to do that and replace the 2020.
Comments:
Sep 05, 2009
- The Uniden-built scanners typically use holding down the #2 key and #9 key while you turn the unit on. I don't know if this scanner is built by Uniden or by GRE for Radio Shack, but if it's a Uniden built unit, 2/9/power should do a reset.
73's
Was this helpful?
Yes
No
Popular Solutions for Radio Shack Pro-2018 Scanner
Questions and Unsolved Problems for Radio Shack Pro-2018 Scanner
Do you recommend Radio Shack Pro-2018 Scanner?
Answer
Answer
after I orogram frequencys in they look as if they are receiving but I hear nothing or squelch on my... (More)
Answer
Radio Shack Pro-508. The lock out key and program key do not work anymore. What's the problem?
Answer
i am looking for new berlinville station 17 frequencys and i cant seem to find it starting monday i... (More)
Answer
radio shack pro 2018 seems to fine but it makes a popping sound moving form freq to freq why? is it... (More)
Answer
I use the scanner to monitor water tower level, so it stays on one frequency all the time (never... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Radio Scanner Experts
Top Audio & Video Equipment Repairmen
in , HI
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
