No display my mercury 810 motherboard no display, i have used a phd pci card, they show the reset led is on, what is the problem
  • gjnfhjj Nov 23, 2008
    my motherboard coplaynt no display model k8v mx
  • 118 Answers
Can post some more info
Posted on Feb 07, 2008
Whats the best graphics card for my motherboard of mercury p4vm800m7??
This motherboard has built-in AGP8X/AGP 3.0 Display with 64MB shared ram. If you want to install separate graphics card, there is AGPUltra slot available on the motherboard and 3 PCI slots. It is your choice what graphics you use.
Jan 11, 2016 | Mercury Computers & Internet
What kind of graphic cards work with Pvm900m
http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=748
Specifications > Expansion Slots > PCI Express x16
http://en.wikipedia.org/wiki/PCI_Express
PCI EXPRESS 2.0
"PCIe 2.0 motherboard slots are fully backward compatible with PCIe v1.x cards. PCIe 2.0 cards are also generally backward compatible with PCIe 1.x motherboards, using the available bandwidth of PCI Express 1.1. Overall, graphic cards or motherboards designed for v2.0 will work with the other being v1.1 or v1.0a."
-> PCIe 2.0 graphics cards are ALSO -> Backward Compatible <- with PCIe 1.0, or 1.1 motherboards.......
-> Using the available bandwidth of PCI Express 1.1
[ PCI Express 2.0 = 500MegaByte per Second, per lane data rate.
PCI Express 1.0 and 1.1 = 250MB/s, per lane data rate.
PCI Express 2.0 = 5.0GigaByte per Second transfer rate
PCI Express 1.0 and 1.1 = 2.5GB/s transfer rate
Will you notice? NO
Regards,
joecoolvette
Jul 15, 2012 | Mercury Computers & Internet
I have a PI865D7 mercury motherboard when i start the pc, computer turn on fan is running all light on but no display in moniter i check the ram, it is ok so please could you help
you may re-seat your ram, video card and processor and pci cards. Turn it back on and see if that works. If you have to do that often then your motherboard has a bad connector or socket on it. If you just installed somthing on your pci slots take them out. If re-seating your ram video card processor and pci slots doesn't work, remove all pci cards and try, If that method works, install them 1 at a time and see when it stops working to isolate the problem.
Good luck hope your motherboard isn't shot,
Christopher
May 27, 2012 | Mercury Computers & Internet
Need emachines T3304 motherboard connection diagram
The eMachines T3304 Desktop PC uses an FIC K8MC51G motherboard.
First International Computers { Inc}
http://www.e4allupgraders.info/dir1/motherboards/socket754/fick8mc51g.shtml
http://support.gateway.com/s//MOTHERBD/FIC/105554/105554nv.shtml
Click on Product Views, then on - M-Front Panel Connector
The plastic front of your eMachines is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
Sometimes abbreviated as F_PANEL, or FP1.
Looking at the motherboard installed in the computer case, the Front Panel header is at the Bottom/Right.
http://support.gateway.com/s/MOTHERBD/FIC/105554/105554mvr4.shtml
The above link shows the pinout, of the Front Panel header.
(Note* The Front Panel header may not be Orange in color)
It is the Second header over from the bottom/right side.
The pins are numbered.
Starting on the TOP row, from the RIGHT side going towards the LEFT;
Pins 10, 8, 6, 4, and 2
Starting on the BOTTOM row, from the RIGHT side going towards the LEFT;
Pins 9, 7, 5, 3, and 1.
A) Pins 1 and 3 are for the HarDDrive Activity LED light.
The LED light that blinks when the harddrive is in use, or active.
Pin 1 is for the Positive ( + ) wire.
If the LED is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch (Button), IF a Reset switch is used.
C) Pin 9 is for 5 Volt power. I believe if memory serves, that it is ONLY used by the factory.
D) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive wire. ( + )
If the Power On LED light is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) Pin 10 is N/C. Not Connected.
(Note it states - Key
It shows you where the pins are. What order they should be by the missing pin)
The FIC K8MC51G motherboard;
1) Has a Socket 754 processor socket.
AMD processors fit in this processor socket,
http://en.wikipedia.org/wiki/Socket_754
2) The motherboard chipset is an Nvidia C51.
It is part of the GeForce 6 series, and more specifically, the GeForce 6100 series,
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6100_and_6150_series_chip_specifications
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_6_.286xxx.29_series
Using this knowledge you can see what Processors are supported, and what Ram Memory is supported, (And how much)
AMD Sempron, or AMD Athlon 64 processors, with up to a 1000MHz Front Side Bus. (FSB) { That fit in a Socket 754 processor socket)
DDR Sdram ram memory that is 200MHz up to 400MHz.
(PC2100, or PC2700, {333MHz}, or PC3200)
{184-pins. 92 on each side}
OR,
DDR2 Sdram ram memory that is 400MegaHertz up to 1066MHz.
(PC2-3200, or PC2-4200/4300, or PC2-5300, or PC2-6400, or PC2-8500)
{240 pins. 120 on each side}
Your motherboard uses DDR Sdram. (184 pins. 92 on each side)
Maximum TOTAL Amount is 2GigaByte. (2GB)
Maximum Amount for EACH ram slot is 1GB.
3) Has one PCI-Express x16 slot for a PCI-Express graphics card.
The PCI-Express technology used for the motherboard is
PCI-Express 1.1
HOWEVER, you can use a PCI-Express graphics card that is based on the PCI-Express 2.0 technology.
PCI-Express 2.0 is Backward Compatible, with PCI-Express 1.1
You just will Not get the full capability of a PCI-Express 2.0 graphics card.
Will you notice? No
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 21, 2012 | Computers & Internet
Cannot show the display
Video might be dead. Install a video card. AGP or PCI and see if you get video.
May 05, 2011 | Mercury P4VM800M7 Motherboard
I have intel p3 e810 motherboard that not give display i cheked ram and processor in other boatd allright
download driver detective install automatically it will download from internet try this for VGA card driver
Mar 09, 2010 | Computers & Internet
Hi,my motherboard in not booting after connecting new power supply,power supply is OK,motherboard lights are on.But when start button is pressed its not showing anything
Try this site //www.dealextreme.com/.Repair tools cheap !! You need PC Motherboard Repair/Troubleshoot Boot-Failure Diagnostic PCI Card
Price: $2.57 free-shipping_small.gif PC Motherboard Repair/Troubleshoot Boot-Failure Diagnostic PCI Card costs $2.57 and free shipping.Great company.need help majortom350@yahoo.com PC Motherboard Repair/Troubleshoot Boot-Failure Diagnostic PCI Card
Aug 22, 2009 | Computers & Internet
Need to connect Mercury PVM900M motherboard cables
my name is Allan kaitila from Tanzania
I bought a motherboard Mercury PVM900M,but i dont know how to conect it.
So may I have its Diagram that shows
The following wires and send it to me through allanafricanboy@yahoo.com
1. SYS_FAN
2. CPU_FAN
3. ATX_12V1
4. POWER SW
5. RESET SW
6. H.D.D LED
7. POWER LED
8 MIC
9. L-RET
10. L-OUT
11. R-RET
12. R-OUT
13. G
14. USB1
15. G
16. USB2
17. G
18. SPEAKER
Feb 25, 2008 | Mercury P4VM800M7 Motherboard
Computers & Internet Logo
413 people viewed this question
David Payne
David Payne
