Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Fridge not cold - freezer fine
We have a kenmoore elite side by side that will not keep the fridge cold. Two questions... 1 - is there supposed to be any ice at all on the coils in the back of the freezer and 2- could it simply be an air baffle problem?
    Problem Solver:
  • 10 Answers
Ice buildup will most likely block the air flow.
if so the air will not be able to enter fridge section. Check air vent in fridge side if you can hear the fan and get no air flow then its blocked - common defrost thermostat failure.
to temporarily clear the problem just use a hair dryer on the ice build up area
Posted on Aug 04, 2009
Kenmoore elite 106.57706701 fridge and freezer
is there ice build up on back wall of freezer? if so evap coils are iced up and fan cannot flow air across them due to ice build up.
remove back wall and hair dryer them free if the ice start up fridge and see if it cools if it does bad defrost cycle, if not compressor or condenser fan bad
Aug 27, 2014 | Refrigerators
What is the temperature suppose to be inside fridge?
fridge is supposed to be around 36-38 degrees freezer 0 to 10 depending on if your fridge area is not cold enough the freezer is the only side that actually gets cold and there is a fan located above the evaporator that pushes to cold air through a small door that opens and closes depending on how cold your unit is. If the unit gets to cold the door shuts not allowing any cold air to come into the fridgerator side. If you have any further questions message me back. Please also remember to rank how this opinion has helped in your appliance situation when our chat has fully completed it allows me to continue helping others in similar situations in the future Thanks Rick
Jun 11, 2011 | Whirlpool Refrigerators
Kenmore elite fridge, french doors, bottom freezer: water does not come out cold. What should the temperature settings be at (for fridge and freezer)?
Fridge 34-38 degres
Freezer below 29
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I recently had to throw away some questionable food that had partially thawed in the freezer cabinet of my kenmoore, model# 253.67882508 fridge with freezer on top. i keep this fridge in my garage and in...
probably,there is a garage kit available that willallow it to work at colder temps,listed in owners manule under accessories the thermostat senses refrig compartment temps.soif garage temp is below 40 or so the thermostat just doen't turn the unit on enough or not at all
Jan 17, 2010 | Refrigerators
Fridge side is loosing cold.\the freezer side is working fine.
Check for proper operation of the damper door. This allows cool air from the freezer to cool the fridge.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 28, 2009 | Maytag Refrigerators
I have a kemore elite fridge wont get cold
It can be the defrost timer,defrost element or defrost thermostat or a blocked vent into the fridge
Aug 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
KENMOOR 59672253200
I was out of town and the top part, the refrigerator part lost the coldness. The freezer which is on the bottom is working ;just fine.
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
298 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
