Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
1997 k1500 chevy 4x4 5.7
The truck starts to run like **** after 20 min then stalls will not start but after 10 min run good for 20 min new tune up new cam /carnk sensor new o2 senser new head gaskets does'nt over heat at all no trouble code when runing good but when it stalls cam sensor code comes up it has a new can sensor and has new ignition control module and coil new gas filter may be its BCM ??? or fuel pump ?? can some help me thanks jeff
  • Anonymous Apr 01, 2014
    driving home from work at 3 am truck running fine all at once motor shuts down and all power. comes back on after appx 5 mins and starts back and i drive 20 more miles home.
  • 466 Answers
You have to check when the engine is stopped if it is missing spark or fuel because the engine is stopped for lack of spark or fuel to be able to verify that a better diagnosis. Thank you
Posted on Aug 02, 2009
2000 jeep grand Cherokee cuts off in 29 min cools off runs 20 min
which engine>>
so you have 20 mins to find the cause, not sit and drink beer.
check for spark.
on all cylinders........ using the 100 year old way, we all should know.
ok say spark is good (if bad , scan it while bad, bingo got DTC>?)
sparks good
i NEXT use test fuel.
it starts and runs
it starts and stalls in 3sc
or does nothing
IN this order, unless want to do compression test hot fail.
watch scotty , do his magic. (100 years old this, magic, now.)
http://www.youtube.com/watch?v=064Ilsz8Fzg&NR=1&feature=fvwp
Sep 14, 2014 | Jeep Grand Cherokee Cars & Trucks
Accent 2000 runs well then stalls once hot and will not start till cooled off
Check your coolant level and overflow bottle for proper fill. Or try running it With radiator cap loose to see if it still stalls. If it still stalls and coolant levels are good you need to check temp sensor. May be more than One. If you did install a new one, it may have been faulty or damaged. If all that fails then try an idle positioning sensor. The spring may be worn.
Sep 24, 2012 | Cars & Trucks
I have a code 58 anti-theft system fuel enable circuit on a 1993 chevy pick up i need to know what this is exactly and how to fix it?
if the truck will not run
then put the key in trun truck on do not start wait 10 to 20 min. then trun keyy off and try to start.it will reset itself
Aug 29, 2010 | 1993 Chevrolet K1500
2000 2.0 vw shutt down after running 20 min
Replace the fuel pump relay, it's easy and cheap.
Jun 08, 2009 | 2000 Volkswagen Jetta TDI
1997 s-10 truck runs for about 20 min after that shuts off
replace the fuel pump relay.if all good .do a compression test .if it pass test i am looking at ignition components.
Apr 27, 2009 | 1997 Chevrolet S-10 Pickup
Hard start
Its your fuel pump.I had the same plomblem not too long ago.I was spraying either in to start it.I have a 97 chevy truck witch requires 65 psi to start and 55 to run properly.You need to find out much psi you need to start it.You can probaly look in your manual or just make a few calls.My truck had 55 psi and it ran fine i just had to get it running first.Good luck.I wonder if that fuel pressure regulator was a waste of time like it was for me.
Nov 13, 2008 | 1997 Chevrolet K1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
439 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
