Question about Linksys Wireless-G Music Bridge (WMB54G)
I have a wireless G music bridge connected to my receiver in another room. The Wireless G access point is connected to the router at the pc where I stream music. The connection to the receiver is lost. The music bridge shows up on the PC and when I shift from Listen to Music from Speakers (on the pc) to Listen to Music on Wireless G music bridge, the music stops at the PC and the icon in the tray at the bottom of the screen turns green, indicating the link is now made to the music bridge. But no music comes out of the speakers connected to the receiver in the other room. It has worked off and on for the couple of years I have had it, but often the problem was that the music bridge was not showing up and I would have to reboot the pc and the access point. But this problem is different. A couple of weeks ago an IT person from my office came and said that through some kind of updates that had been routinely performed on my computer he thought the music bridge software had quit working. And it worked for a week or so, but now it's the same thing -- no connection to either of the two receivers that each has a wireless G music bridge connected to it.
  • 6 more comments
  • nate241 Aug 01, 2009
    There is only one computer involved and it's operating on Windows xp. There are two g music bridges, one upstairs and one down, each connected to a separate receiver. Neither is getting the music from the PC although both show up on the PC when you scan for music bridge.
    nope. tried it both ways and no luck.
    it is connected. no music playing.
  • nate241 Aug 02, 2009
    I don't have a solution so I trust I'm not being charged for what I have gotten to date: ". . . unplug the music bridges, go through the utility to see if the bridges are connected (they were)."
    This is unsatisfactory.
    Unless there is some way that it could have switched frequencies, it should match because it has worked for 2 years. And it worked 10 days ago. I don't know of any way that the frequencies would have gotten switched or changed from what they were when it was working . . . and wouldn't it fail to connect to the bridge if the router and bridge were on different bands?
  • nate241 Aug 03, 2009
    how do you do that? rollback the updates? to a prvious date? and will microsoft cause the updates to happen again automatically that will wash out the changes?
    ok. i will try this tonight when i get home from work. i do have XP.
  • nate241 Aug 07, 2009
    Finally had a chance to try this tonight and -- no luck. It still won't stream through the bridge. I reset to July 25, a date when I know it worked because I was home listening to the music on my porch.
  • 4,924 Answers
See if into the router isn't blocked the access of the G unit .....at the wireless settings it has a some features where you can restrict access either by password or by mac ...or just select certain frequencies ..take a look on wich freq. its the wireless G on ...and select the router to broadcast in the same ..I believe that it has a range from 6 to 12 or so ...
Posted on Aug 02, 2009
  • 2 more comments
  • Catalin Turcu
    Catalin Turcu Aug 03, 2009
    ok..I understood, you are saying that since the streaming appears to be ok ..and the actual wireless G shows up on pc...the connection it right ...in this case the problem might be from the physical connection from the G unit to the receiver ,,check the cables ..the plug-in to be ok ..and if its the same as they always been when they work ...I think it will be a solution to roll back your computer settings ..( system restore ) to a date when you remember that it worked...cause the automatic Updates from windows sometime makes changes on drivers or so ..and some issues does appears in the process...
    so ..if you do not see any faulty in the way your wires are plugged ..that this restoring on an earlier date ..might just solve this ...so try to restore the pc ...to a date that you remember it worked...and if its any settings issue this will fix it
  • Catalin Turcu
    if you are running xp ..the easiest is to go to start/ all programs /accessories../system restore...there select to go to a previous date ..next and there will appear a calendar with some dates in bold digits.. those are points of restore and the system can be restored to one of those dates...so choose one in the near time you know the system worked fine ..and try ...I am not sure but on vista might be about the same ...the same thing can do from control panel and choose from task to run category view ..and choose maintenance ...and it will appear in the side task the system restore...I believe for vista its about the same ..with some confirmations for administrator rights... try it ..and let me know ...and indeed the automatic updates do make from time to time changes even on the network driver ...and maybe it done such a thing and its no longer compatible with the other part of the system ( G unit )
  • Catalin Turcu
    after this ..if you find a restore point and it actually reversing ..you can be sure that if it doesnt work its something from the other part ..maybe from the receiver ..or so... please let me know how it end up ..cause Im kinda hooked on this stuff and I end up wondering for days if I dont know..
  • Catalin Turcu
    Catalin Turcu Aug 07, 2009
    ok..at least at this point you know that the configuration on the pc ..is optimal ..and the problem is not on the streaming ..so you have to concentrate upon the receiver ..and its settings and wire-ing ..cause there can not be any thing else...try to see what can be wrong ..and to be sure that the actual G unit is receiving signal ..try to amplify for a check into something else...anything you have in near by...and can get and play audio signal...if it works ..it means that the actual receiver has a problem ...
What operating system are both computers running? Which one is the one where you cannot hear the music?
Posted on Aug 01, 2009
  • Anonymous Aug 01, 2009
    Try powering down one of the bridges, and then try playing to the one that is turned on. Does it work? If not, power does that one, and turn on the other and play to that one. Does it work?
    Thank you for your reply.
    The green icon in the tray for the utility doesn't actually indicate immedietely that a connection has been made. It simply means the utility has taken over from Windows's own sound playback.
    1. Check that both bridges are on. Check the ulility icon on your computer is green.
    2. Open the utility (possible by double-clicking on its icon or right-clicking it and choosing Open or similar)
    3. Go to the Status tab (it should already be on it by default)
    4. If your Music Bridge isn’t displayed in the list, click the Scan for Music Bridge button
    5. Once you see both bridges appear, click Connect (not Connect to PC's Speaker)
    6. The status for the bridge should change to Connected in green bold text
    7. Use the volume slider at the bottom of the utility page to adjust the volume to maximum. Ensure the Mute button in the center is not pressed.
    Test music playback to the bridge. Ensure the speakers connected to the bridge are turned on and try adjusting their volume.
Can I use one wireless router to connect to my primary wireless router?
You wouldn't use a wireless router for the second device -- you would use a wireless bridge device. Most Wireless Access Points can be configured to be wireless bridge devices or you may be able to find a dedicated wireless bridge. Unfortunately, these devices usually have just one Ethernet port. That will mean that you'll need to buy an Ethernet switch in addition to the device that you're going to be using as a wireless bridge. This will add to your cost and make it so there is no real cost savings by using the Wireless Bridge + Ethernet switch combination.
If you can find a wireless bridge unit that has more than one Ethernet port, then you may be in business.
Using a second wireless router will not work unless the device has the ability to be configured to be a wireless bridge. Such routers are usually more expensive than your typical router, but you might get lucky and find one at a good price.
Good Luck
Feb 09, 2012 | Linksys Computers & Internet
How do i set bridge mode?
Depends if you need a wireless or wired bridge?
Here is some info for you.
Infrastructure Mode
With a wireless Access Point, you can operate the wireless LAN in the infrastructure mode. This
mode provides wireless connectivity to multiple wireless network devices within a fixed range or
area of coverage, interacting with wireless nodes via an antenna.
In the infrastructure mode, the wireless access point converts airwave data into wired Ethernet
data, acting as a bridge between the wired LAN and wireless clients. Connecting multiple Access
Points via a wired Ethernet backbone can further extend the wireless network coverage. As a
mobile computing device moves out of the range of one access point, it moves into the range of
another. As a result, wireless clients can freely roam from one Access Point domain to another and
still maintain seamless network connection.
Wireless Bridging Overview
Using Wireless Router as a Wireless Access Point
May 03, 2011 | NetGear RangeMax WPN824 Router
Internet connection is fine when my PC's connected directly to the modem. The router connects fine. But won't let the wired PC online. Under the "status" bar the "router" tab won't show the correct...
here are times when there is a need to connect a wired computer to an access point in order to set it up. To connect a wired PC to a Linksys access point, follow the steps below. Step 1:
Connect the PC to the Ethernet port located at the back of the access point.
Step 2:
Assign a static IP address on the computer. For instructions, click here.
NOTE: To assign a static IP address using Mac, click here.
The Access Point can be configured in four different modes:
  • Access Point
  • Access Point Client
  • Wireless Repeater
  • Wireless Bridge
The Access Point mode allows wireless clients to connect to the access point and routes traffic between the wireless and wired interface. Use this mode to create a standard wireless Infrastructure network. For instructions, click here.
The Access Point Client mode allows this device to act as a wireless client. You can connect a wired PC to the access point to connect to a wireless router or another access point wirelessly. You can enter the MAC address of the Access Point or use the Site Survey button to select the Access Point you want to connect.
NOTE: The WAP54G will only communicate with another WAP54G when set to the Access Point Client. For instructions, click here.
Sep 05, 2010 | Linksys Wireless-G WRT54G Router
Cannot connect my WAP-0005 Access point to my router
Use AP mode ; but may really have some compatiblity issues though... Good Luck*
Mar 11, 2010 | Levelone WAP-0005 (DHWAP0005) 802.11b/g...
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do I set up a router to extend the range of a wireless hub?
You would normally set it up as an access point. But bridge would work too.
Jan 10, 2009 | D-Link DSL-G604T Wireless Router
Linksys Wireless WRT54G vs. WET54G
For what it is worth, I fhave found streaming video does not function well using a wireless connection. The options of multipale routers will work as long as you configure them as to not have conflicting IP address assignment's via DHCP, and the routers do not have matching IP address's. Never fear all is possible with paticence. BPCS
Jan 20, 2008 | Linksys Wireless-G WRT54G Router
Dropped connection
Step 1:
Connect the Wireless-G Music Bridge to your router using an Ethernet cable. For instructions, click here.
Step 2:
Access the Wireless-G Music Bridge’s web-based setup page. For instructions, click here.
Step 3:
When the Wireless-G Music Bridge’s setup page appears, scroll down to the Wireless section and look for Wireless Mode and select Infrastructure.
Step 4:
Look for the Wireless Network Name (SSID) field, enter the wireless network’s SSID.
If this doesn't work let me know
Aloha
Bob
Dec 13, 2007 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Linksys WAP54G connection to WRT54G
Ok, so why do you need an access point upstairs and a router downstairs connected wirelessly? If you can't connect with a laptop or a pc, why whould you think you could connect the access point? The purpose of this configuration would have to be with the access point to the router via ethernet. What's the point? If the problem is range, check out http://www.dd-wrt.com/dd-wrtv2/index.php to enhance the capabilities of the WRT54G... and maybe building a parabolic antenna for it as well. Plans to do so abound at Lifehacker.com.
Sep 05, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Cannot Connect Gaming Console or Remote Computer to the Internet
1. Make sure the gaming or remote computer has a correct IP address with the same IP subset address as the wireless router or access point. 2. Turn the bridge off. 3. Turn the bridge on. 4. Recheck the IP address for the gaming computer or remote computer. 5. Turn off all network devices. 6. Power on the wireless router or access point. 7. Wait 30 seconds. 8. Power on the bridge. 9. Check to ensure the bridge connects to the wireless router or access point. 10. Power on the gaming console or remote computer.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Linksys Wireless-G Music Bridge (WMB54G) Logo
218 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
