Question about Hotpoint NBXR463EBWW Electric Dryer
Dryer willnot stay running
Dryer willnot run unless I hold start button what should I check
    President:
  • 1,714 Answers
The start relay itself seals in and keeps you running.
Posted on Aug 01, 2009
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Dryer won't stay running without holding down the start button
It may be the centrifugal switch on the motor. The push button starts the motor and as the motor spins up to speed the centrifugal switch closes to keep the motor running. Hope this helps.
Jan 02, 2014 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
I have a kenmore elite quit pac 2 that wont stay running unless you hold the start button down. I dont have much money to fix it but cant afford to buy a new one. What can I do?
  • firstly dont hold your finger on the button
  • by doing this you are running the motor on the start winding
  • this winding is for momentary operation only, just to get things started.
  • You must have a fault in the run circuit of the motor.
  • To save your dryer. dont use it till you get someone who can fix the run circuit. It may only be contact failure, or jammed up with lint.
  • Good luck
Jan 23, 2011 | Dryers
Dryer will not stay running unless you hold down the start button.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 10, 2010 | Kenmore 63932 Electric Dryer
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 10, 2010 | Kenmore 63942 Dryer
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Hotpoint NBXR463EBWW Electric Dryer Logo
308 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
