Question about 2wire (1000-400108-001) Router
Can't connect one laptop
I am using a Home Portal 1000SW Modem/router, and have been for several years. I have a Mac G5 with an ethernet connection to it--no problem. I have a Mac G4 with wireless connection--no problem (well, sometimes it loses it, but that is another complaint. Rebooting solves it. BUT, I have a G3 older laptop that, until recently, accessed the home network beautifully, but has now lost its connection and I cannot figure out why. I have reloaded the 2Wire software and it is successful up to connecting, then it just cannot do it. Any ideas? I did see the inactive laptop for a while on but now I don't even see that.
Any help would be appreciated!
  • dshayne Dec 13, 2007
    Thanks for replying and sorry I didn't answer sooner. Never got an email saying there had been a reply.
    Both laptops are used inside the home and without WEP or WPA setup. I do have a home network setup using this...there is one G5 attached by DSL modem and then two other MAC laptops which are airport enabled. One of them is no problem. It is just the other that is having 'issues'. Does this answer your questions? I sure do appreciate your help!
  • 116 Answers
Ok this is a simple, but difficult fix at times. I need to know if the other laptop is used in and or outside of your home? In addition I need to know if you have security like a WEP or WPA setup? Do you have a home network setup using this router/modem? I may have other questions, but these I need to know in order to give you an exact answer!
Posted on Nov 26, 2007
I have my computers and laptop networked through my 2wire Home Portal 1000SW modem and am trying to connect my Coby Kyros MID8024 Tablet through wifi. The tablet finds my 2wire network but seems not to...
1st make sure that your using the proper WEP key (Wireless Password) 2nd make sure that their wirelessly compatible SW is a wireless b compatible to eliminate this issue you may also disable your WEP
majority of new technology uses wireless G and N
this wireless modem is a little bit outdated:
Data Link ProtocolEthernet , IEEE 802.11b , HomePNA 2.0 , HomePNA 1.0 , USB
see for your tablets protocol if this would match:
Aug 28, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Share Your Internet Connection with More Than One Computer- The Easy Way
Here is a simple way share your home internet connection with more than one computer. This will work for both wired and wireless and doesn't require alot of technical or computer skills to accomplish. I'm sure there are other ways, but if you're looking for a simple repeatable setup, here it is.
If you've got a dsl connection through a dsl modem, this TIP will work for you.
If you've got a cable modem, this TIP will work just as well.
Here's a list of what you'll need.
  1. Dsl or cable modem that works on your system and you can access internet with one computer (If you're using the internet, most likely you've got this already).
  2. Wired (Ethernet) or Wireless Router (wifi routers have 4-6 ethernet ports also).
  3. For Wired: Ethernet cable to connect modem to router.
  4. For Wireless: Wifi compatible computer or wifi card for your computer (follow manufacturer's instructions for proper install).
  1. Turn all components off. This includes anything on your existing network- computer, modem, printer and any router you may currently be using.
  2. With all power off, connect an ethernet cable between your modem and your new cable/dsl router(wired or wireless).
  3. Turn on the power to your new router only and let it boot up completely.
  4. Turn on the dsl/cable modem and allow it to boot. Since the router was booted first, the modem with recognize the router's MAC address (ethernet numerical address) and connect that address to the internet.
  5. Connect all the other components onto the router with the ethernet cables as needed and turn on the components- no particular order is necessary after the router and modem are booted. Your router will assign MAC addresses to all the ethernet components. Once the MAC address is assigned, your computer should work correctly with the internet and shouldn't drop out when the second computer is turned on.
  6. For wireless connections, boot up your computer with the properly installed Wifi card, airport card and allow it to "find" your router. Once you get confirmation of the signal, you're good to go.
Following this procedure will allow your modem, your router to use their designed software to connect you without a bunch of programming. You will actually enjoy having more than one computer sharing an internet connection.
Remember this procedure and follow the steps again if you lose power and have to reboot your network.
on Dec 04, 2009 | Computers & Internet
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Connect internet via ethernet
to use dhcp with several computers, you need to have a box that allows the dhcp mode and which is configure to goes on
Jan 17, 2009 | Apple Power Mac G5 Desktop
I bought my daughter a laptop (elonex onet) but i dont no how to put internet on it thanks ceri
You have this in the Mac Laptops category, but it's not a Mac. This laptop is running Linux.
The Elonex ONEt has wireless Internet connectivity. That means you can use a wireless router in your home in order to use it online. If you already have one, the system should be able to set itself up to use that connection on its own when you open a web browser. The web browser on your system is BonEcho/Firefox.
Another option is to run a Cat5e, also called an Ethernet cable, line from a router (or from your cable modem or DSL modem) directly to the laptop, since your laptop also has an ethernet port. This looks like a regular phone jack, but it's a little bigger.
Best of luck!
Jan 05, 2009 | Computers & Internet
Cant connect my G5 to the Router to get internet
two things to consider. There are two different types of Ethernet cables out there. Perhaps you have a one way cable for the second one. To test this, unhook the working cable from the mac that gets internet and then hook that one up to the one that doesn't get it. See if it sees the network after a minute. The other issue might be in the Operating System. You might need to make sure that they are both up to date with all of the latest updates installed. (I know, hard to do with out an internet hook up.)
Lastly, make sure you are plugging in the cable to the right place on the back of the router. Seems silly, but some of the best have accidentally put it into a link plug to connect several routers rather than an actual Ethernet plug.
Dec 22, 2008 | Apple iMac G5 Desktop
Home portal not yet activated
XP is an very good OS which will connect with 2wire without any problem.
If your computer is not able to detect modem, pls follow these steps.
* Check for damage of ethernet cable
* Try to reset the modem by using a paper clip punching into the reset button
* Even if your modem is not detected, force the IP and Default gateway
Take care
Feb 26, 2008 | 2wire HomePortal 100W (1000-400026-000)...
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is Try this instead of to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
Dlink Router not assigning IP to NAS
DI-624 (Update to FW 2.70+)
Dec 28, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
2wire (1000-400108-001) Router Logo
156 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
