SOURCE: canon printer displays error
CANON
PIXMA MP450
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will turn off printer.
2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
3. you will let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
6. you will turn off printer by button POWER.
SOURCE: Canon PIXMA MP140 error code E 2
error E 2 =>
The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
SOURCE: Canon Pixma MP160 All in one deskjet printer Error code E 2
Please can you tell me what the error code E 2 & 7
SOURCE: Canon pixma MP600, error code 5010, what does it mean
There are a few things you can try:
The overall issue with error code#5010 is a scanner malfuntion. If the problem returns, check the ribbon cable as it runs from your scanner to the main logic board. If all is secure and you still have the problem, the printer may need a new logic board.
Testimonial: "Thenk you very much for your assistance, I will try your solutions. regds Robert"
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
