Question about Kenmore Refrigerators
The bottom of the fridge is filling up with water from the frezer how do i stop it.
  • Kenmore Master
  • 4,655 Answers
This is a common problem and I want you to click on the link below,
Let me know if this helps or you have another issue to resolve the problem, Thanks, Sea Breeze
http://appliancepartstec.blogspot.com/
Posted on Aug 02, 2009
Samsung RF263 icemaker not filling with water
the fridge has an electric solenoid valve to let water in (just like your clothes washer) it is located where the water line goes into your fridge at the bottom in the back find,check, clean or, replace it.
Dec 03, 2013 | Samsung Refrigerators
The fridge is not working.the freezer is working.in the freezer the cold air is not coming in the fridge.
fridge basics
the fridge and freezer are seperate compartments they dont share air there is a chemical filled filiment on your fridge u can see it at the back looks like a big grill that chemical is pumped around both fridge and frezer that chemical carrys heat energy it removes the heat from the fridge and frezer to the radiator at the back this radiator gets verry hot whyle your fridge / frezer becomes cold it shuld be 1 compleate system with better fluid flow in the frezer to make it cool faster
ok so the frezer is working but fridge is not it could be a few things 1 fluid not geting round the fridge lack of fluid or 2 a blockage
im no expert but knowing the basic science of fridges is a help i hope this has helped but like i say im not farmiliar with any fridge and models deviate but the science stays the same hopefully this steers u in the right direction
Oct 30, 2012 | Refrigerators
Fridge/frezer not cold,only at the bottom,act like fan that blows across coils is not working,how do I fix
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 04, 2011 | Maytag 25.6 cu. ft. Wide-By-Side...
Freezer is not defrosting. it's a RF265ABPN model
Your defrost termination sensor has failed & needs to be replaced.(very very common problem with todays fridge's specially samsung)
Feb 21, 2011 | Samsung RF265AA Bottom Freezer French Door...
Pan under refrigerator is full with water and over flowing
do u have checked temprature of the frezer,u have to empty pan time to time to prevent overflowing
Dec 28, 2010 | Whirlpool Refrigerators
The fridge is not working and the frezer has a low temperature
be carefull when you remove the panel inside the frezer it may be you have a build up of ice and the panel could get frozen to the ice, best idea is to turn off the fridge/frezer for 24hrs to let it thaw
Oct 15, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Ice in bottom of frezer
make sure your doorgasket is sealing correctly. if the water runs out it shows that the defrost heater is working.
Aug 07, 2009 | Frigidaire FRU17G4JW Refrigerator
Amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Fridge Frezer
Hi I am the lady with the freezer that keeps icing up at the bottom and then dribbles water from the door when you open the door. Did you say to pull the freezer out and do something at the back of unscrew the little panel that is inside the freezer at the bottom?
Jul 14, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
103 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
