Question about Sewing Machines
Machine does not hold any stitch except straight and seems to make unusual noises when i try to move towards other stitches(basting) etc It does not get real heavy usage,only occasional for home sewing. and was serviced about 1 yr ago.Is this a simple repair or a major overhall for a technician.If it requires a Major repair,does the Manufacturer honor any guarantees if less than 10 years from purchase
  • Sewing Machines Master
  • 1,388 Answers
Although you have not provided your machine details, very few manufacturers of anything give a 10 year warantee, and certainly exclude fair wear !?!?
Have you inserted a new needle and re-threadedplus cleaned out around the bobbin case and hook race just to be sure of basics first ?
When you have done that, just try a simple zig zag....if it now catches the stitch that is it, if not it may be timing.
Here is a LINK to details of how to adjust timing for Shuttle and Rotary, both front and top loading machines.
Posted on Aug 02, 2009
Is the Kenmore sewing machine 15343 able to do a baste stitch? If so, how?
A baste stitch is basically setting the machine to a straight stitch with the longest stitch length available. Loosen the top tension slightly if you want to remove the basting later.
May 12, 2017 | Kenmore Sewing Machines
I want to baste and dont know how to set straight stitch and length.
To baste, set the stitch length as high as possible (zero is a non-stitch length, probably 4 or 5 on your machine is the largest stitch length). Set the stitch width to zero so there is no zig-zag.
Jan 09, 2017 | Sewing Machines
How do I set the machine to do a basting stich
if the machine can do a basting stitch the information should be in the sewing machine manual, if you don't have a manual, add a comment with the name and model number of the machine and someone should be able to help you find one.
or you can also try youtube for a video
May 11, 2016 | Sewing Machines
How do I set the basting stitch length? when I try, it just beeps at me.
A BASTING STITCH IS ONLY A LONG STRAIGHT STITCH. THE NUMBER THAT IS LOWER IS A LONGER STITCH (FEWER STITCHES PER INCH). YOU WERE LIKELY MOVING YOUR NUMBER HIGHER. AFTER YOU GOT TO A CERTAIN NUMBER IT NO LONGER QUALIFIES AS A BASTING STITCH BUT A STRAIGHT STITCH. USE A LOWER NUMBER AND IT WILL LIKELY TO STOP THE BEEPING.
Sep 30, 2014 | PfaFF Sewing Machines
Kenmore 1941 sewing machine irregular stitches
try rethreading the machine top & bobbin make sure to get ever thread guide
try chaning to needle, make sure the needle goes all the way into the needle holder-normally flat side goes to the back of the machine
check to make the thread is moving smoothly around the tension dial
if these suggestion don't help, then the machine probably could use a servicing
Mar 13, 2012 | Sewing Machines
How do I set for basting
Some compuerised machines will have a basting stitch programmed in, it may have a symbol like a dot then a long dash then another dot. This will give you a decent spaced basting stitch. On mechanical machines sometimes you can get a basting needle plate - you set up for the longest widest zigzag stitch and the tube on the plate makes one side of the zig not catch so you get a long straight stitch.
But if you are joining silky fine fabrics together, then needle and length of thread doubled is still the best way, takes a little longer but the fabrics won't creep and slip.
Oct 23, 2011 | Brother PS-1250 Pacesetter
I have an elnita 255 and bought it brand new way back when...the problem I have is I can not get this machine to do a baste stitch. since I bought the machine new it has never done basting. Even when I...
The straight stitches can be shortened and lengthened utilizing the length selector. If you are attempting to do this with zigzag the stitch will be the same distance but the fabric will appear as if the material hardly moves. This will be changed by using a wide stitch. If you can't truly get a different stitch length on the straight stitch you may need the feed dog adjusted by a pro so that it will give you a longer stitch.
Nov 29, 2017 | Sewing Machines
I am wanting to set my machine (quilters dream 6603) for the best basting stitch I can. I am having trouble figuring out how to set the machine. Thanks.
I haven't been able to find a 6003 manual or a good image of the stitch range for this machine on line. However, a basting stitch might look like " . _____ . _____. " on your stitch selector. As your machine is targeted for quilters I'd have expected it to have a basting stitch in its range.
If there is nothing like that, then just dial up the longest possible straight stitch, ie take length up to 4 or 5, whatever the maximum number is. Then loosen off the top and bottom tensions and stitch away.
If you are using this to baste a quilt top, botton and batting together, I've discovered a product called "spray basting" which is fantastic and "glues" the layers together while you sew them. You need a big clear floorspace though and put paper down under the project. But it works great.
Trust this is of help to you.
Apr 12, 2011 | Elna Quilter's Dream 6003Q
Won't stitch properly
it sounds like you might need a new bobbin case to me try that and see if the issues you are having stop hope this helps
Sep 20, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
