Question about HP Pavilion dv6000z Notebook
Battery not charging.
My laptop battery is staying at around 30% and that percent goes down when i don't hae the power cord in the laptop but doesn't go up when the cord is in the laptop.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 144 Answers
I have the same problem at times. The life of laptop batteries is short if you are always connected to the internet. To save battery power / to increase the life of your battery overall and during each use, disable the internet when you are not using it.
Click on your "Local Area Connection Status", which is usually represented as an icon in the task bar menu at the bottom (blue bar) of your screen. Open that up and then click "disable" whenever you are not using the internet.
Unfortunately, at this point you might need a new battery though.
I hope this helps!
Sincerely, CBR2009
Posted on Aug 01, 2009
Acer laptop not charging lite don come on but its not power cord
It may be a problem with charge retention in the on/off switch. Try this.
1. Take out the battery
2. Remove the power cord.
3. Press the on/off button and hold it for 30 seconds. This will discharge it.
4. Leave the battery out for now, and replace the power cord.
5. Turn on the laptop.
If it boots up, all is well, power down the machine, reinsert the battery, and use as normal.
Nov 14, 2013 | Cell Phones
Batter wont stay charge
Most laptop batteries have a life expectancy of two years or 400 to 450 charge and discharge cycles. After this time, the battery may lose the ability to charge or to hold a charge for substantial periods of time. When this happens, it's likely the battery needs replacement. However, troubleshooting can narrow the problem and ensure you are not wasting money on a battery replacement.
Check Power Adapter Turn the laptop off. Remove any power cords or power sources. Separate the battery from the bottom of the laptop. Slide or press the locking mechanism to unlock the battery. Slide the battery out of the battery compartment. Plug the power adapter into an electrical outlet. Insert the opposite end of the adapter into the charging outlet on the side of a laptop. Power on the laptop. If the laptop does not turn on, the power adapter is not correctly working. If the power adapter is not working, the battery can not charge. Replace the power adapter. If the laptop powers on, the power adapter is properly working. Clean Battery Contacts Turn the computer off. Remove any power cords or sources. Take the battery out of the battery compartment. Dip a cotton swab in isopropyl alcohol. Rub the dampened swab on the battery compartment and battery contacts. Dust and buildup can prevent battery contacts from properly charging. Slide the battery back into the battery compartment. b> Charge and Test Battery Plug the power adapter into the laptop. Charge the battery for six hours. Remove the power adapter. Turn the laptop on. If the laptop turns on and stays on for at least 30 minutes, the battery is holding a charge. If the laptop doesn't turn on or the battery doesn't power the laptop for at least 30 minutes, the battery should be replaced.
Battery Won't Charge Or Short Power Life In Notebook
http://www.daileyint.com/hmdpc/battery.htm
Laptop Battery Depot http://www.laptopbatterydepot.com/problems.asp - clean
Feb 24, 2013 | Computers & Internet
I have a new violation 9053 and first time to charge the green light blinks for about 10 seconds and then goes off and thje battery is now dead it seems, no lights, no power
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 01, 2012 | Computers & Internet
My notebook is not turning on,how do i know if its the battery
When you plug in the power cord is there anylights whatsoever on the laptop, where the plug goes in or on the AC Adapter ofthe power cord?
Mar 31, 2012 | ASUS Computers & Internet
Hello,my laptop didn't get started it is charging
How do you know it is charging? What does it do when you hit the power button?
Mar 30, 2012 | Computers & Internet
Comp.will not boot starts screen no signal goes off
Mar 29, 2012 | Computers & Internet
Wont turn on
Mar 28, 2012 | Computers & Internet
When i turn on, the green light comes on then goes out,why
HP Pavilion dv6000z Notebook Logo
41 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
