Onkyo sl107 replacement power transformer
Any idea where i could order a transformer with number TTI230010120 or can I use a similar type this being a 230v/100w but what is the secondary voltage ,.It has three wires obviously centre tapwith twowhat I think is 12v output
  • fatman101 Nov 26, 2007
    same problem need a replacement transformer for a onkyo SL-107 sub what can i get to fix it
SOURCE: JCR-160 clock radio Clock running slow
The clock works off the frequency (hertz). In US the electrical wave frequency is 60HZ/sec and in India and many other countries 50HZ/sec. Hence, the clock slows down about 6 seconds or so every minute.
Posted on Nov 28, 2007
SOURCE: Mikomi TV power pack/transformer/AC adapter replacement
Power Plus Online sell a replacement ac adapter 'PSU 1' at www.power-plus.tv we purchased one recently for £29.95 and this works fine.
Regards Steve
Posted on Dec 30, 2008
SOURCE: Philco 841.205 Power Transformer
Hi:
...I have a brand new one exactly the same (Philco) that I will sell you for ten bucks.... but I don't know where you are?
Please e-mail me at: brodi@telus.net
Posted on Mar 24, 2009
freetek
  • 5568 Answers
SOURCE: No power when plugged in. On off button stays dark, nothing works
Everyone has problems with SMPSs; mine started in 1971 when IBM was first using them; they were literally blowing up and throwing molten copper several feet.
Anyhow, if you have the benefit of a capacitance meter with DF function, check the main filter caps all of the smaller caps. The quality and durability of electrolytics is bad and getting worse and once one of these fails anywhere in a feedback path, the supply will not start. HF is hell on electrolytics.
The (ferrite) transformer in a switcher measures very low on the Ohms scale; depending on power handling and service frequency, primary <<100 Ohms, secondary from 0.? - 10 Ohms between taps, because they operate at higher frequencies. The 50 volts from the diode bridge is way too low; you probably have failed 100-200 uFd. electrolytics right close to them although this is fairly rare since they are only working with 120 Hz. From a 120 VAC line, you should have ~ 160-170 DC volts at no load if the caps are still working as they should and you have no notable resistance between the AC and the diodes.
Well-designed switchers are wonderfully efficient and very reliable if the maker didn't cheat on component quality. I've repaired literally thousands as a sideline in a now retired business and after studying them and adding a ceramic cap.or two and better quality electrolytics, they will run for decades. At one time, I had standard repair prices on ~ 70 different models.
My guarantee was 'lifetime' and that was limited only because I retired.
Posted on Aug 20, 2009
Testimonial: "Thanks fo the tip and taking your time to answer! Great insight! "
  • 21 Answers
SOURCE: HP printer AC power adaptor 0950-4399
I just get one from www.order-bulk.com my print is working now
Posted on Nov 19, 2009
The type of audio power and the number on onkyo A917 amplifier
Hi
Usually there are 2 transistors for each channel, if you don't know the numbers on the transistors.
there is another way to get as close as possible to have equal or similar to the same type of transistors (NPN/PNP)
example: 2SA is PNP transistor.
there are (2SA/2SC) transistors and there are (2SB/2SD)
complementary transistors
1: you have to know the supply voltage for the transistors
2: choose transistors that it is equal to the current and voltage that suits the supply voltage.
follow this link to find suitable transistors.
be aware and be careful that there other parts you need to check on the power amplifier circuit, resistors,capacitors and drivers etc...
I would suggest (2SD1047/2SB817)
http://www.smcelectronics.com/DOWNLOADS/COMPTRANS.PDF
Good luck
Hope this helps
Jun 25, 2016 | Onkyo Audio Players & Recorders
If I would buy a Onkyo TX-NR616 in the US (110V) and take it Europe (220V), wouldn't it be a solution to simply exchange the power transformer for a 220v one?
An stepdown transformer is needed should you buy in US and use it Europe
However, if your on a technical side , trace the primary windings , and check
There are European versions which are already 220V, no need to convert.
Source : page EN 99 of the Onkyo TX NR616
manual
Sep 24, 2012 | Onkyo Tx-nr616 7.2 Thx Certified Network...
I have Onkyo HT510 receiver. does not turn "ON".
hi,
There is a standby transformer inside the Onkyo receiver at the mains input stage. If the standby transformer is faulty then the unit will not power on. There will be two transformers. One is big and the other is a small one. The small tarnsformer is the standby transformer. Which will be fitted on a small board where the power cable is connected. Replace the transformer to rectify this problem.
OK
Oct 15, 2011 | Onkyo HT510 Receiver
Screen went out, sound works but screen does not. Power on light flashes 7 times on start up
Flyback transformer [LOT] short. Replace the same with similar type and number, and replace the horzontal output transistor alongwith it.
Oct 16, 2010 | Sony KP-53HS10 TV
If i accidentally plugged it to 220 volts and it was burned in a seconds can it be repaired?
Good day sir/maam, Yes it can be repaired. if you have plugged in a 110v device to a 220v ac mains, chances are its toast, your onkyo's power transformer is burnt, the repair is replacing the toast power amplifier, or we usually rewind the power transformer specification, after the replacement, you may need to check the power supply section for shorted power regulators, and rectifiers. If you choose to send it for repairs, the service is usually reasonable.
Oct 26, 2009 | Onkyo TX-DS777
I have a Dacor microwave DMO24 oven which i think is manufactured by Sharp. when the cook function is started it will hum/buzz for about 1 second and then blow a fuse. from the sound, and it's...
It is indeed made by Sharp.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
OR, we have the service / repair manual for this model and have uploaded it to our site here to help you.
The parts list is here.
You can order Dacor parts
here.
If you prefer to order the original Sharp parts (which are usually considerably less) look for the part number on a tag on the transformer or capacitor (whichever is bad).
The part number for the capacitor will be similar to RC-QZBOl8MREO and the transformer number will be similar to RTRN-BO59MREO. Again, these numbers are examples to show Sharp's number format.
You can order Sharp parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
May 18, 2009 | Sharp R-1480 Microwave Oven
Seems like Power supply burned up
If the high voltage transformer is fried, the high voltage capacitor or clamp diode may be at least partially shorted (causes transformer overload). Usually this blows a fuse immediately to prevent a transformer burnout. Arcing in the oven waveguide or cavity, or a magnetron fault could also have been the cause. It would probably be a good idea to replace the magnetron controller relay also; it probably was overloaded.
Given the price of the replacement parts, your best bet would be to find a similar unit at an electronics recycling place and combine good parts to get a working oven. The keypad on your oven is worth something since keypad failure is common in that particular line.
Jul 03, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
ONKYO MC35TECH aka R-805X
Hi if you need a replacement plug for the system then you can buy them from any electrical store but if you want a transformer or anything product specific then you can contact Onkyo USA sevice centre on 201-785-2600.
Here is the Onkyo website where the number is from
. http://www.onkyousa.com/customer_support.cfm
Or for European service centres go here: http://www.eu.onkyo.com/indices/index_com_en_2008_5946251.html
Oct 29, 2008 | Onkyo MC35Tech CD Shelf System
'phones engaged' no sound
Well,
My onkyo receiver was keep displaying "Phones Engaged" and no sound.
All I did was plugged in a phones plug and remove it and for the last 2 weeks there is no problem.
I just happened to have a phone plug (without the actual headphone or wires) and that seems to fix the problem.
Hope it will work you all of you as well.
Good luck.
May 26, 2008 | Onkyo TX-SR502 Receiver
My Onkyo Receiver TX 601 is turning itself off
Several things can cause this: Loud signal passages can momentarily draw high currents at the mains, especially if you have unit plugged into power stripe with other equipment. Or if unit is plugged into isolation transformer, current draw may exceed output of transformer. Too many speakers hooked to output or if one is bad (partially shorted due to overheating)
Apr 04, 2008 | Onkyo HTR500 Receiver
504 people viewed this question
 Grubhead
Grubhead
