Question about Northern Industrial Tools Welding Tools
Turn on power and hook up air, ground cable connected, squeeze trigger on torch, no response
  • 1 more comment
  • odmann Aug 01, 2009
    Northern Industrial 375 plasma cutter
    All appears good.
    Turn power on the fan starts as it should the power light comes on
    I have taken all connections loose and cleaned and put them back on
    I believe I may have a broken wire inside the torch lead.
    Is there a way to check it without pulling the wires all out.
    It has worked fine the last three days. Pull up on the job site today and nothing.
    Normally when you squeeze the trigger the work light comes on but today nothing.
    Thought something else might be wrong so I plugged it into My Lincoln 8 and struck and arc and the low voltage light came as it should have. So I figured the internal board was probably good.
    Did that too.
    Brought it back to the shop and plugged her up still nothing
    President:
  • 1,723 Answers
First thing is the obvious, are the connections good and tight. Is there power to the machine and everything look good. Which machine are you using?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Aug 01, 2009
  • 3 more comments
  • Craig Butler
    Craig Butler Aug 01, 2009
    Open the red handle up and be very careful and take a look for the wire.
  • Craig Butler
    Are there any fault lights on showing any problem?
  • Craig Butler
    All that is in the head is the main + wire for the output. You may have something going on inside. Are you sure the AC supply is 240 volts?
  • Craig Butler
    Can you check the 240volt AC from the Lincoln?
  • Craig Butler
    Well, that's it then, you're going to either have to get in and look at things or have a tech look at it. I may be able to help you if you see something...
I have a accurate tools 3n1 stick,mig, and plasma cutter everything works except the plasma press the trigger air comes out but no arc at all on tip to metal can hear the relay clicking when switch between...
Could be as simple as having the ground cable connection placed into the wrong port on the front of the machine. Foot peddle/machine selection switch in peddle mode instead of machine mode? Internally it could be high frequency spark leakage or failed HF circuitry. These are the most common causes of spark failure. Oh and be sure you have good consumables and they are installed correctly. Air pressure leaving the torch head should be around 70 psi.
Aug 27, 2014 | Welding Tools
Car wont crank at all. lights wont turn on or any power. checked out battery and alternater, they are fine. what is the problem
Check both the battery connections and the ground connection on neg wire. Also the positive main line to the starter. All connections should be clean and tight with no corrosion. There are some smaller wires on the positive side of battery too. Make sure all are securely attached.
Check positive cable for seperation where it drops down from battery hook up.
I had this problem too. Ended up stripping the end of cable and soldering the wires into the battery terminal connector squeeze clamp. Retaped it with weather proof rubber tape.
If that dont do it, I dont know what else to say except try to get the ear of a mechanic familiar with Nissan. Maybe there is a master power relay..?
Good luck.
Be very carefull if tightening connections, not to short out the positive side to frame / body ground with your tools. Can be very dangerous.
Jun 22, 2011 | 1997 Nissan Quest
My air impact runs without squeezing the trigger.
if u take the tail outa ur gun u will see that da gause filter inside has broke up.it gone inside and holding da valve open pick it out wit a seal pick r somethin
May 27, 2010 | Ingersoll Rand Air Impact Wrench 1/2in....
Only cuts for 3 seconds, device still on
Possibly an internal short in the torch tip... the expendable components failing in the tip will cause the sensors in the machine to register a "no cut" or "free air arc" state and kill the power to the tip to prevent damage to the unit. Replace the tip components and double check the grounds connections.
Apr 03, 2010 | Hobart Airforce 250ci Light Weight Plasma...
No arc. Power and Air OK
if the main power cable is cut that is your problem,unit uses high frequency.the two leads go to the gun trigger back to unit,no fuse or fuseable links in the gun.
May 13, 2009 | Welding Tools
Equalizer doesn't turn on
hookup the remote wire of your EQ to that of the HU or just simply connect it to the positive line but it would make your EQ powered ON all the time. That remote wire of your EQ is to get a trigger signal from the HU so that it will turn the EQ "on".
Apr 20, 2009 | Power Acoustik PWM-19 4-Band Car Equalizer
No power to the cutting torch when the trigger is pressed
check to make sure all torch parts are in good shape and is put in correctly
Mar 11, 2009 | Welding Tools
Welder will not weld even when I touch the wire from the gun to the ground clamp it will not burn off
Basic electricity, + and -, electricity needs a metallic path to follow, on the - side, start by inspecting the connection where the ground cable plugs into the machine. These connectors often wear out and sometimes they lose their connectivity. Wiggle it, feel it, visually inspect it, move on down the cable, are there any splices? I've seen them spliced in numerous places with black tape everywhere, and the owner's standing there scratching his head wondering... Check where the cable attaches the clamp, is it secure and tight? If you're satisfied the ground side is in good condition, then troubleshoot the +side. Now, how the torch side works is there are two electric paths that need to have connectivity. The first is a wire that connects inside the cover of the welder, runs all along the whip to the trigger, where it's connected to a switch (trigger), then follows back down the whip to the machine. If anything happens when you squeeze the trigger then this is all working properly, logical? If nothing happens, check the connections we just discussed. The other path is how the high voltage gets to your work. At the machine, connected to the wire drive is the liner of the whip. Where this is clamped to the drive is the connection, inspect it. then the electricity travels down the liner to the contact tip, which is how the electricity gets into the wire. If they put the electricity into the wire at the machine, the wire would be glowing red hot and melting all through the whip, because the resistance is the same as at the tip of the wire, get it? But the liner itself is heavier metal than the wire, so the resistance is less, so it doesn't heat in the liner, following? So if you pull the shield off the end of the handle, you'll see the contact tip that connects the + liner to the moving wire inside. Inspect it closely. If you still have no current flow after these inspections, there's still hope. Somewhere on the machine there should be two or more fuses. Find them and inspect them, if any are burnt, be sure to replace it with the same size and amp fuse. I'm sure that if you follow these steps, your welder will be working just fine before you know it. Please post back your results.
Feb 05, 2009 | Hobart Handler 140 Mig Welder
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Welding Tools Logo
56 people viewed this question
Top Northern Industrial Tools Welding Tools Experts
Bill Boyd
Are you a Northern Industrial Tools Welding Tool Expert? Answer questions, earn points and help others
