SOURCE: DVD player reloads after 5 minutes into the movie
I have a K715 that was having the same problem. The "line select" had been switched from "in" instead of "out". Once I switched it back to "out", the player worked normal.
SOURCE: playing movies through usb port?
The options when you play a DVD it will appear when you are connecting ext HD it will not work.
Better you need the play in a DVD Disc to get the good sound.
SOURCE: DVD player is not able to detect WD 320 GB hard drive
Try reformating the drive with FAT32 file system (this is the default facotry mode).
Thanks,
Siva Kaza
SOURCE: can I connect a usb portable hard drive to the TVSony Bravia Sxrd
no you cannot connect directly you will require to connect it through you laptop .
SOURCE: grinding noise whle movie plays on portable dvd player
Is it happening with all the dvds you play on it, if so then you should clean the drive with a branded dvd drive cleaner.
