Question about Frigidaire 14 Cycle Tumble Action Washer
What does "err" and then "loc" mean? my washer will not start and this code keeps flashing. Frigidaire tumble action washer is the type I have
You press the two buttons on either side of the lock icon for about 15 seconds and it clears it.
Posted on Aug 03, 2009
HOW TO CLEAR THE LOC CODE ON MY FRIGIDAIRE WASHER
This means that the child lock (control lock) feature is active. There will be a button (or pair of buttons) depending on the model that you need to press and hold to toggle off the feature. If it is a single button, there will be a tiny padlock icon on the button. If you need to press and hold two buttons, the padlock symbol will be in a line indicating both buttons.
A likely combination is the Select and Option buttons. These should be held together for 10+ seconds. (This is the combination for some Affinity washers.)
If this doesn't work and you can't see a lock icon, please add a comment with the model number of your washer. I'll be glad to check what the combination is for your washer. The model number is usually on a plaque on the rim of the door for front loading washers or at the back at the top of the drum for a top loading washer.
I hope this helps.
(the control lock prevents someone from accidentally changing the cycle or a child starting a wash cycle with the cat or another child in the unit)
Nov 23, 2011 | Frigidaire 14 Cycle Tumble Action Washer
My washer won't start, it keeps flashing ERR and then the wash-time, and then LOC. My roommate says to fix it before, he held down three buttons, but can't remember which ones. Any idea?
Try the following two buttons: press Options and Select together for 10 seconds (or until the LOC disappears). The pair of buttons held for 10 seconds also sets this control lock.
To find out the error code, turn the Program knob to the start position, Spin Only. Press Start/Pause to start the cycle. Press Cancel to stop the cycle and turn off the LEDs. Press Cancel again and within 5 seconds press and hold the Options and Start/Pause buttons until the LEDs start chasing. Then release the buttons. Turn the Program knob seven clicks clockwise from the Start position. The control will signal the last error code. To clear the error, press and hold Options and Start/Pause for 3 seconds. Then either unplug the washer for 5-8 seconds before plugging it back in. Alternatively, press and hold Options and Start/Pause together for a few seconds until the Wash LEDs appear.
http://www.applianceblog.com/mainforums/frigidaire-electrolux/12950-frigidaire-atf6000es1-wont-drain.html has a link to the service manual for the listed washer (the link is half-way down the page).
I hope this helps.
Oct 12, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a Kenmore washer (417.44082400), which is displaying alternately the following information: ERR LOC 37 The 37 indicates the usual minutes for our customary Permanent Press cycle. When Start is...
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 07, 2010 | Frigidaire Affinity ATF7000E Front Load...
ERR LOC on display
Your door lock switch needs replacing.
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
When start is pressed ERR LOC displays, door
You can try clearing the code and then running the machine. Try colding down the pause and clear button simultaneously for three second s and the faul should clear Or try turning the knob around 9 times to clear the fault.
Jan 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 417.44092500 front load window shows Err then flashes LOC and the minutes for the particular load setting. Door doesn't lock. Tried to get into diag code setting on spin/drain and pushing pause &...
Mar 08, 2009 | Washing Machines
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
LOC message
This sounds like a faulty micro switch on the door catch. Try pressing inwards on the door glass at the catch area whilst you press start and hold it oressed for a few seconds until it either starts or displays the error again, if the error shows it may require a new switch, the switch can be tested by bypassing it and joining the two wires together that plug onto the switch. The switch can be accesses by removing the dor seal from the outer most edge.
Jan 26, 2008 | Washing Machines
LOC message
thats a rotor lock position need to ck motor
Jan 08, 2008 | Kenmore 44102 Front Load Washer
Frigidaire 14 Cycle Tumble Action Washer Logo
306 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
