Getting new system How many Tons would a Rheem Air handler with model#RHQA-0805B? Thanks
  • leocic Aug 02, 2009
    Can't be, this is a small unit in my house. I have two of these one up and one down. My house is only 2500 Sq. Ft. It is either 1.5 or 2 ton. My outdoor unit is 1.5 ton, I just don't know if they upsized the air handler
The RHQA0805B is a 1.5 ton coils/air handler.
Posted on Aug 29, 2009
  • 30 Answers
The Rheem model RHQA-0805B is a 6-ton unit.
Posted on Aug 02, 2009
I have a rheem model # rhsa-hm3617ja air handler will a rheem model# rxbh1724a15j heat strip work?
typically the compatible heater models are all labaled, different sizes, on the data plate of the air handler.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 01, 2018 | Heating & Cooling
What are the tons of a RUUD AC HANDLER MODEL UBHA-17J11 SO SFFA SERIAL NUMBER MOO500 03485 and what type of CONDENSER & TONS CAN IT HANDUE WITHOUT PROBLEMS?
You can find the tonnage in the model number which increases by increments of 12, so if the model number is 24 =2 tons. Model number on your a/handler is 17. Thats a ton and a half. Really should match the evap and condenser for the best efficiency. ...
Sep 24, 2015 | Ruud Heating & Cooling
Hi, I have a Rheem RHSA HM4221JA air handler with
Sounds like a relay inside the air handler is stuck 'closed'...
Oct 17, 2013 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I just installed strip heat Rheem RXBH-1724A10J 10KW 208/240/1/60 into Rheem 14AJM36A01, RHPNHM3624JC, 3 Ton 16 SEER Air Conditioner Split System W/ GE's Variable Speed thermostat Pro 701 and it ran up...
This will help you.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Jan 20, 2011 | Heating & Cooling
How old is a rheem rhqa-122oj air handler and what is the max wattage.
ampsxvoltage=watts so if you know the amp draw should be on machine and voltage just multiply as far as age undetermined
Feb 02, 2010 | Heating & Cooling
Hi,my name is PK I have 5 tons Rheem air handling 10 year old. it is vertical type. How to fix the leak at evapolator coil. it leaked at the bottom right side. Can I use epoxy to seal this leak.Or replace...
Epoxy wont hold you need a new coil. about 8 to 12 hundred depending on your location. If it is 10 years old I would suggest you change the air handler. You will get a lot more efficient unit. Cost about 2200 but you will get a 10 year warranty from most manufacturers. Dont buy one unless you get a 10 year warranty. Russ
Jul 28, 2009 | Heating & Cooling
Rheem Air Handler will not run. This is a 2006 Rheem model RHLA-HM3617JA Air Handler. I replaced both the condenser and air handler circuit boards. I replaced the motor in the air handler.. The condenser...
Have you hard wired your fan motor to verify that the motor and or the capacitor are good? If you do a continuity test of the motor leads(with electricity off of course) you can see if the motor has open or grounded windings.
Apr 11, 2009 | Ruud Handler Air Conditioner
Btu's
That air handler can accamodate different size coils. Look for the coil model number. Also you can look at the outdoor unit model number they should be matched up. There is generally a set of 2-3 numbers in the model numbers that will tell you. xxx036xxx is 36,000 btu. tonnage is 12,000 btu per ton so 36,000 btu's would be 3 tons. xxx040xxx= 40,000btu's or 3.5 tons etc.
Mar 16, 2009 | Heating & Cooling
Heating & Cooling Logo
377 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
