Question about Dehumidifiers
Ice is forming on the coils - delonghi dehumidifier
  • Anonymous Mar 29, 2014
    ice formed on coil near the top
    Guru:
  • 587 Answers
Check your filter, indoor coil and blower wheel to see if they are dirty, if they are they need to be cleaned, if not then you are probably low on refrigerant or Blower speed to low. If the blower doesn’t run when you turn the switch to on then you need to check the blower out, especially the capacitor.
Posted on Aug 23, 2009
Dh25 the cooling coils get frozen,the appliance sill working even the canister is full.
The normal operating temperature is above 65 F. Much below unless specially designed for low temperature they will freeze up.
They have a frost detector and will defrost but it is very inefficient and not practical. My experience they eventually form a block of ice on the coils. They heat the room in the process so in a moderate area they can raise the temperature and provide needed circulation.
In the past where the temperature is cool I have faced the output into a corner, raised it off the floor and once the unit got started the heat created from the unit kept the air warm enough to avoid freezing up the coils.
Always check for recalls. Some models have had problems and have been recalled. See the link below.
Gree Reannounces Dehumidifier Recall Due to Serious Fire and Burn Hazards...
Hope this has helped?
Jan 13, 2016 | DeLonghi Dehumidifiers
Ice formed on coils of ad 70 uss
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Sep 10, 2011 | Whirlpool AD70USS Dehumidifier
Ice forms on coils/piping
heatman101
Aug 15, 2011 | Goldstar DH304 Dehumidifier
My dehumidifier does not seem to be working properly. I can't find the manual to tell me what the settings should be. Would appreciate your help. It is a DeLonghi DE400P. Thanks Shirley
What is the specific problem? Is no water being collected by the dehumidifier or do you have another issue?
Make sure that the dehumidifier is in a room in the operating temperature range (at or above 44 degrees F). Make sure that the room door and windows are closed and that the room is not larger than 2200 square feet. Make sure that the collection bucket not full and is properly seated in the dehumidifier. Check and clean the air filter on the dehumidifier. (Vacuum the filter or rinse under running water three times. Then wait until dry to replace it in the dehumidifier.) Look at the coils of the dehumidifier. If you have ice on the coils, defrost the unit (turn off, unplug and wait for it to melt). If the ice reforms quickly, you may have a leak in the coolant system. Then the unit needs repair.
Next make sure that you have good air flow around the dehumidifier and that the desired humidity set point is lower than the humidity of the room.
Retrevo has the manual available: http://www.retrevo.com/support/Delonghi-DE400P-Heating-Cooling-and-Air-manual/id/19269bh037/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Aug 09, 2011 | DeLonghi Dehumidifiers
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
Delonghi 500p freezes up at bottom left of coil and then does not dehumidify
heatman101
May 29, 2011 | DeLonghi DE500P Dehumidifier
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
Dehumidifier ices up
unplug and take unit apart,blow out dust then carefully spray some cleaner-degreaser on and wash both condenser and evaporator coils,then let dry throughly, try not to soak the electrics too much a little will dry, let dry throughly then start it and leave it run a few minutes carefully touch top of compressor head,if quite warm and one line isn't hot and the other line isn't cold entering and exiting the compressor and evap coil starts to ice again you may be low on freon(refrigerant)
Aug 29, 2009 | DeLonghi DE500 Dehumidifier
Icing up on our dehumidifier
typically happens when there is a lot of dust in air. Try cleaning it VERY well, which would mean, shutting it for a few days, letting it melt and dry off, then not only vacuuming it, but then take an air gun (or Air in a can) and get the dust off the coils. Obviously if there is a filter clean it, or replace it.
Check for bent fins on the coil. Most of the newer ones (and yours should as well) have an auto defrost to help with that.
Good luck
Jun 25, 2009 | DeLonghi DE40P Dehumidifier
Frost, ice on coils DeLonghi DDE50E Dehumidifier
expected? of course! this is not ur solution try draining all the water to the sewerage if u cant try to pump it out with a vacuum cleaner (that can pump water) or a pump then turn on the Dehumidifier every time it frosts turn it off untill it defrosts or u can heat up the basement with a bellower and the Dehumidifier wont frost
Feb 05, 2006 | DeLonghi DDE50E Dehumidifier
Dehumidifiers Logo
387 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
