Question about Ricoh Aficio 2015 Copier
The SC 542 error code How do I solve this problem without having a technician come out and fix something I can probably solve myself
  • 2 more comments
  • helpmetechie Aug 02, 2009
    Thanks but can you tell me where this is located on the machine and how I can get to it to replace it? Haven't worked on copiers before other then paper jams. It is first experience with Ricoh Product also.
    Thanks
    Where is the thermistor & the thermofuse located? How do I get to it and change it in the Ricoh Aficio 1515 copier?
    ginko, I have the Ricoh 1515 and that machine doesn't have a online + escape buttons. I do have the error code SC 542 and others have stated The fusing thermofuse & the Fusing thermistor needs to be changed. The problem is I don't know where this is located. Can you give me step by step instructions on how to remove and replace this. (WHERE ARE THEY LOCATED IS #1)
    hI GINKO, I did as you instructed I pressed the clear mode button (yellow) then I pressed the 1 then 0 and then the 7 after that I pressed the clear button (orange) the message that came on the screen is as follows:
    [Sp Mode] No.
    1 copy sp 2
    3 4
    (B1295531c)
    I then turned it off and then on again. after I turned it back on the message that came up was:
    Error occurred SC: 542
    Turn main pow3er switch off then on. if the problem occurs again call service.
    ginko can you guide me from this point?
  • 375 Answers
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared.
The magic keystrokes, clear the error code:
The Fix
In order to clear error SC542, you must perform procedure 5810.
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared.
Posted on Aug 03, 2009
  • 346 Answers
SC542 error = Fusing temp. warming-up error.
The fusing temp. does not reach the fusing standby temp. within 125 seconds after the main power switch is turned on.
Causes:
Thermistor defective or out of position
Fusing lamp open
Thermofuse open
BICU defective
Power supply brd defective
Poor connections
ALWAYS DISCONNECT THE POWER FROM THE WALL BEFORE WORKING ON MACHINE
*** replace the thermistor AND the thermofuse*** If one went bad then the other will probably go bad soon. ( 95% it is one of these). You can check lamp first by disconnecting one end and putting a meter on it to see if it is open -- if open then replace.
Posted on Aug 01, 2009
  • Joy Shannon
    Joy Shannon Aug 02, 2009
    I am sorry I can't tell you where they are located. I am sure someone on Fix Ya can help you. I did some research and that was the answer I came up with. If it is over your head I personally wouldn't mess with it and would call a rep to come out and fix it. I am sorry I couldn't help you further.
  • Ricoh Master
  • 19,396 Answers
In order to clear error SC542, you must perform procedure below.This works on most Ricoh.
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
On Aficio MP 5500 and similar you have to
press the yellow “C” button
enter 107
press the red “C” button and keep it hold till the display changes
turn the power off with the big red switch on the front side
turn power on again.
to reset a Ricoh CL7300 (or CL7200) with a SC 542 error: 1) Enter Service Mode by holding down Online + Escape and then turning on the printer
2) Hold down keys until System version appears & the 1st option (1. System) appears.
3) Arrow down to #2 - Engine & press Enter.
4) Arrow down to # 5 - Mode & press Enter.
5) Arrow up until you see SP5810 - SC_Reset, & press Enter.
6) You will be prompted to Execute? - press Enter. Resulting message should say results OK.
7) Turn off printer, wait 5-10 secs & turn on again. Should be OK; if not, call Service.
Posted on Aug 02, 2009
  • Ginko
    Ginko Aug 02, 2009
    Hi there
    SC 542 is a fuser warm up error. Very rarely it is the fuse temp sensor.
    Usually the printer start SC542 because required fuser temp had not been reached in max time, that can happen for a number of reason.
    Most common is that you can just reset the error enering in service mode and clearing NVram
    Try this procedure:
    Clear Modes
    Press 1, 0, 7
    Hold Clear/Stop for 5 seconds
    The display should say service mode now.
    Turn power off and then back on while in service mode to reset NVRAM.
    If the error comes back you may need to replace fuser (most common) or fuser temperature sensor.
    Let me know if the procedure applies to your model, if it does not I will get the service manual for this model, I will need more time in that case.
    If the error is cleared, then please do not forget to leave feedback.
    Let me know if it does not clear.
    All the best .
    G.
Turn main power switch off then on.If error reoccurs.call service.Functional problems. What does mean.
It means that something with the functionality of your device is not working properly. Take it for service.
Mar 07, 2016 | Ricoh Aficio 1018D Copier
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Hi, i have a error code SC 542 but i don't see Yellow Key [clear modes] button on control panel please send me deatil moeen_rauf@yahoo.com
SC 542 Heat roller warm-up error and for that you will need a technician since the machine may need some part replacement .
Feb 15, 2011 | Ricoh Aficio CL7200 Laser Printer
WON'T DO ANYTHING RIGHT NOW...SHOWS ERROR CODE SC542-00
sc 542 is a fusing error code. i think the thermostat or the thermistor could be bad. have it checked by a technician.
Jan 04, 2011 | Office Equipment & Supplies
I have a ricoh aficio sp c420dn, when and turn on the screen showing error sc542
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while
on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
Jan 10, 2010 | Ricoh Office Equipment & Supplies
Service Code SC 542
That is fuser code and needs to be reset in the service mode, it will not go away by turning the off and back on.
May 29, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Im having an error sayig SC:542 so how can i solve this kid of problem?
This is a 'fuser" warm up error. You could have a blown out heater lamp, or fuse, but most often this is caused by a power fluctuation. The reset for this is done by simply entering the service mode, and turning the machine of/on with the main power (red button).
enter service mode as follows:
"Clear Modes"
" 1, 0, 7 "
then hold "Clear/Stop" for 2-3 seconds.
The display will change with "service mode" in the top corner.
Now turn power off/ on (red switch)
** Never go further into the service mode, as you can cause all kinds of difficulty.
If the code comes back, then you will have to get a technician on site to troubleshoot the fuser.
Please rate me :)
Apr 24, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Can i have solve my proplem is sc 542
sc542 is a fuser code that needs to be reset by a service technician. It may be just a dirty sensor or it could be something more serious. Contact your local Ricoh service tech for assistance.
Oct 20, 2008 | Ricoh Aficio AP4510 Laser Printer
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015 Copier Logo
5,980 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
