Question about Kenmore HE5
F11 SHOWS ON THE PANEL. - Kenmore HE5
  • 6,784 Answers
HI. This is a Serial communication error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.(usually the wiring harness will need to be replaced in this case, but a faulty Motor Control Board is not uncommon)
Posted on Aug 01, 2009
Spot on screen
Do you mean dead pixels or a dirt spot ??
A dirt spot, use hot water on a soft cloth to clean it.
Dead pixels, you can try this, keep moving between screen and sometimes this will unstick bad pixels.
Go here, then click F11, now RT click mouse button as fast as your finger can. do it like 20 times.
Now click F11 on the page that shows the words dead pixel test.
If they are still there you will need to check your warranty and see how many the company allows before they will fix.
http://deadpixeltest.net/
Apr 13, 2013 | JVC JLC37BC3000 37 Class LCD HDTV - 1080p,...
Washer stops beeps shows F 11
Hi
Thanks for using FixYa. Error F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). This usually occurs when CCU goes bad however, to check what has gone bad you’ll need to remove the top panel of the washer and also remove the rear panel to access the drive motor & MCU. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag the washer quits and a f20 or f11 shows up
Its a water inlet problem (no water or insufficient water supply) check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Apr 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
The F11 error. Where is bottom panel?
f11 serial communication error.communication between the central control unit {ccu} and the motor control unit {mcu} cannot be sent correctly.
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a G1220SC model. F11 shows on the panel,
F11 is a drain error.
Water outlet restricted.
** Check for kink in the drain hose.
** Clean the filter combination. (p.41)
** Clean the non-return valve (check valve) (p. 53)
** Check/clean the drain
Unplug the machine.
Disconnectthe drain where it enters the S bend from the sink. You may find thenozzle into the S bend is blocked. Probe it with a screwdriver andclear the blockage.
Plug in2_bing.gif the machine and re-try.
THIS MANUAL
may not be for your model - however it will give instructions on some of the steps above.
If all checks out - the pump will need replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 25, 2009 | Miele Dishwashers
Error Code F11
TRY UNPLUGING IT FOR A MIN OR TWO. I THINK F11 IS A CONTROL MODULE. CALL A TECH
Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My menu bar is gone, ther is nothing at the top of the page but the address bar. I can't even see my favorites or any thing esle
Click on tools,Explorer bars,and select what you want showing or if it is just in full screen mode,just hit the F11 key.
May 09, 2009 | Microsoft Internet Explorer 7
How to change day on F11 heart rate monitor?
Paste this link into your browser and download manual:
http://www.polar.fi/en/support/downloads?product=&category=User+manuals&documenttitle=User+Manual+for+F11+in+English+9%2F2007-&document=/gip/PKBStoGIP.nsf/web_cat/C225742500419A8AC225732F0049BE55
Do not forget to rate, please.
Feb 08, 2009 | Polar F11 Heart Rate Monitor
Kenmore HE5 Logo
62 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
