Question about Sharp LC-32SH20U 32 in. LCD HDTV
Sharp lc-32sh20u problem
Turn it on the screen starts off as white with a black stripe across screen, then the screen starts turning black from left to right. then when screen is full got a black screen.please help.
  • 103 Answers
SOURCE: Sharp Aquos LC-32D41U
The unit has bad drive ic's,which is part of the lcd panel.It is not cheap to fix.
Posted on Mar 05, 2008
  • 10 Answers
SOURCE: full screen
The black lines are because you are playing the analog 4:3 picture on a newer 16:9 shaped screen. If you don't have the manual, you can get it by going to www.sharpusa.com and search for your tv model listed. The user guide is available in pdf format.
According to page 35, you need the "view mode" button on your remote. You sound like you want it set to "S" for "Stretch".
enjoy your TV,
Herb
Posted on Sep 05, 2008
SOURCE: Sharp Aquos LC-30HV4U
replace the supply board
or repair it *** there's problem with supply
Posted on Nov 11, 2008
  • 8 Answers
SOURCE: blue screen, no video, but has sound
Did you hit the "input" or "video source" button by mistake on the remote or TV? That would change the input from the one the cable/video source uses. You're getting sound, so it's working......sounds as if the input was maybe changed. I'd hit the input/video source button a few times to go through all the available inputs and see if you get video back.
Posted on Dec 08, 2008
  • 479 Answers
SOURCE: Loss Sync
According to SharpUSA the problem with the "Loss of Sync" error message is that (most probably) the cables (between the box and the display) are not connected properly (so remove and reconnect them carefully, on both units) or a cable is defective.
Also, after you reconnect the cables try turning on the unit, if no success then depress the "clear" button on the external box (under the door on the front and on the bottom left and try turning on the TV again).
It is, most likely, that the cables are not seated properly. Reseat the cables on both the display and the external box.
Hopefully, this will clear the problem
if still does not solves your problem just replace all the cables connected between .u can get the new cables at radioshack web site.just place an order they will provide you. thanks.
Posted on Dec 14, 2008
I have sharp LC-20AX06. when i start it then after 1 sec its screen turns black white green light is stable. kindly guide me.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 05, 2015 | Sharp Televison & Video
Pioneer deh 15ub wire diagram
Yellow - Constant 12 Volt (battery)
Red - Accesory 12 volt (switched) only 12 volts when car in accesory or on position
Black - Ground (chasis)
White/white with black stripe - Front left speaker (black stripe is negative polarity)
Gray/Gray with black stripe - Front right speaker (stripe negative)
Green/green w/ black - rear left
purple/purple w/ black - rear right
solid blue - power anteanna (not all have this wire)
blue w white stripe - remote turn on (used to turn amplifier on or power anteanna)
yellow w/ black stripe - mute (for cellphone handsfree kit)
Jan 21, 2014 | Car Audio & Video
Sharp lc-32sh12u...no picture
It can be either the LCD panel driver board, or the worst case is bad LCD panel.
Nov 18, 2009 | Sharp LC-32SH20U 32 in. LCD HDTV
Sharp 46" 6 months old see rainbow colors from left to right
Did he change the big video board?The main backlight video baord that the prob.
Oct 23, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Audio O/K no picture . Model Sharp LC-32SH12U. Thanks "Larry"
Check for a backlight failure by holding a flashlight on the screen at about a 30-degree angle, a couple of inches from the screen. Look at the area around the flashlight beam. If you see video, either your backlight fluorescent tubes are burned out or the inverter has gone bad. If you need tubes, search for "CCFL replacement" (CCFL = cold cathode fluorescent lamp").
Aug 10, 2009 | Sharp LC-32SH20U 32 in. LCD HDTV
Im installing a new sterio in a 95 mustang ----i need a colour code dia. of the wires on the old factory sterio. Which wire goes where?
A Right Rear Spkr (-) Dark Brown w/ Pink Stripe Purple w/ Black Stripe
B Right Rear Spkr (+) Tan w/ Green Stripe Purple
C Right Front Spkr (-) Green w/ Orange Stripe Gray w/ Black Stripe
D Right Front Spkr (+) White / Green Stripe Gray
E Left Rear Spkr (-) Tan w/ Yellow Stripe Green w/ Black Stripe
F Left Rear Spkr (+) Tan w/ White Stripe Green
G Left Front Spkr (-) Lite Blue w/ White Stripe White w/ Black Stripe
H Left Front Spkr (+) Orange w/ Green Stripe White
I Amplifier Turn On Do Not Use For This Vehicle
J Power Antenna Turn On Do Not Use For This Vehicle
K Ground Wire Black w/ Green Stripe Black
L Do Not Use For This Vehicle
M Dash Light Dimmer Wire Orange (if available)
N +12 Volt Ignition Wire Thin Black Wire Red
O Do Not Use For This Vehicle
P +12 Volt Battery Wire Green w/ Black Stripe Yellow
Jun 17, 2009 | 1995 Ford Mustang
No display on Sharp LC 32sh20u
blue screen,no video but has sound
Dec 18, 2008 | Sharp LC-32SH20U 32 in. LCD HDTV
Blue screen, no video, but has sound
Dec 08, 2008 | Sharp LC-32SH20U 32 in. LCD HDTV
Sharp LC-32SH20U 32 in. LCD HDTV Logo
122 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
