Question about Canon PowerShot A510 Digital Camera
My camera is not turning on even when we put in new batteries.
  • 300 Answers
There could be 3 problems:
  • broken memory card door switch
  • broken battery door switch
  • dead fuse
I have seen all of these on A510 and A520. If you have a multimeter, some experience and like to repair it yourself, I could help you. My e-mail is toms.safranovs@gmail.com
If not, you should give it to a local camera repair shop or Canon service center for a repair.
Tom
Posted on Aug 02, 2009
My camera wont turn on or work even after i put brand new batteries in it... whats wrong with it???
If your batteries did not leak at all, and corrode th points where the. Batteries make contact, then it could be something very serious on the main board, or something simple like the on/off switch. Really it's the sort of problem that needs to be seen by someone. I'd check the battery connections first, then make absolutely sure the batteries are going in the right way around. Flat end is - and pointed tip end is +. Good luck
Nov 24, 2013 | Jazz JDC27 Digital Camera
HI GOOD DAY I CANT TURN ON MY CAMERA IT DOESNT WORK EVAN WITH NEW BATERY THANKS
Check to make sure the batteries are inserted correctly.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.Close the [Memory Card / Battery Cover] securely, and then turn the power on.
If your camera still does not work even after you have performed the above procedures, your camera may be malfunctioning. Please have the camera serviced in this case.
Apr 19, 2011 | Canon PowerShot A460 Digital Camera
Camera always says low battery even when you put in fresh batteries..will not allow me to take any pictures
Hello. Remove the batteries and use the eraser on the end of a common pencil to clean the contacts. Then replace the batteries and turn it on. J.
Jul 10, 2010 | Samsung Digimax A7 Digital Camera
Sanyo VPC-E90 Turns off then back off
If it's really almost new, why don't you take advantage of the warranty?
Apr 17, 2010 | Sanyo VPC-S880 Digital Camera
Won't turn on even with new batteries
Clean the battery contacts inside the camera with a cotton swab lightly dampened with rubbing alcohol.
Dec 17, 2009 | Pentax K100D Digital Camera
My camera won't turn on, even with fresh batteries.
u need not get new camera.use an iron metal to sctrach the bateery terminal of the cameral then put the battery.
Dec 09, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Camera will not turn on
If the camera will not turn on, even though there are batteries in it, there is an actual hardware problem. If you've had this problem since you purchased the camera, you will need to contct Kodak support and they will fix it for you.
Jan 12, 2009 | Kodak EasyShare One Digital Camera
It won't turn on
There could be something going on the battery contacts. Your camera may still be under warranty. I would check it out with Canon
Jun 22, 2008 | Canon PowerShot A560 Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Canon PowerShot A510 Digital Camera Logo
164 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
