SOURCE: Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
SOURCE: Ice maker stopped making ice
the most comon problem is the ice machine in the freezer actuates at low teperatures. actuation is when the unit goes into harvest the ice. if your freezer is not aciving low enough temperature the ice machine stops working ' check to ensure the condensor under the fridge is not pluged with dust .Also make shure there is adiquit air flow around the ice machine. hope this helped someone .
lift the bar up to shut the maker offf and then turn it bakck on and wait.
SOURCE: Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
