Question about AOpen F1713 (Silver) 17 in. Flat Panel LCD Monitor
My monitor glows white when a display is supposed to be on it
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Aug 01, 2009
There is like haze spot
LCD Panel White Spot Cleaning Technique - YouTube
? 4:13
https://www.youtube.com/watch?v=0OzjLMKFYk8
Jun 9, 2012 - Uploaded by joegingCA
Simple Technical procedure on how to remove a white spotproblem of an LCD Panel. ... Don't like this video? ... How to remove liquid spots from LCD screen - Duration: 5:16. ... Building a liquid crystal display (LCD) - Duration: 13:49. ... 2:18:17. Samsung/Mitsubishi/Toshiba DLP TV Repair - Black & White ...Missing: 170s4fb ‎haze
LCD TV - Problem with white glow seeping in from edges - MyBroadband
mybroadband.co.za/.../349324-LCD-TV-Problem-with-w...
MyBroadband
Jul 12, 2011 - 15 posts - ‎9 authors
Results 1 to 15 of 17 ... After googling it seems this is quite a common problem withLCD panels, though I .... Earlier this year I read that Philips have sold off their LCD TV... Yeah, something like that, unless demo stock is treated differently? ... bleeding from the edges as well as in the middle of the display.Missing: 170s4fb
How to Fix LCD Monitor Ghost images - MadeByMark.com
Jan 14, 2016 | Philips 170S4FB 17" LCD Monitor
Why my LCD monitor produces white glowing screen as it turns on
It is likely the computers video board that is failing, my best advice is to have it hooked up to another computer to decide which is the problem the monitor or the computers video card.
Jan 23, 2012 | Computers & Internet
Acer X193W LCD Monitor White Display
Just white/Gray glowing screen?
If that is the case, the LCD panel may have blown fuse or it is not getting the 5 or 12vdc from the logic board.
Learn more here:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 10, 2010 | Acer Computers & Internet
My Soyo 19" widescreen monitor suddenly went all white. Powering off for a few hours does not help, it only glows white. Any suggestions?
It glows white because the LCD controller (part of the LCD panel) is not getting the 5vdc from the logic board or the LCD controller board has blown fuse due to short circuits, see what LCD controller looks like here: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
First thing to look for is to see if the ribbon cables on both ends are in place and have clean contacts.
Mar 26, 2010 | Soyo 19" LCD Flat Panel Monitor
White screen
this is the fault of your lcd screen
it could be your screen jack is loose or damage white screen is coming due to back light is glowing only.it is better to take to some technician or service center.
Jul 26, 2008 | Smart Modular PYXSCAPE SV1170 17" Flat...
Web page looks different on my Notebook
It most probably cause by your PC's display card.
Apr 18, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Have lost ability to control brightness.
lost,
wow a CRT that even glows at all , and you wonder why its dem
the electron gun cathodes get weaker every day of its life.
all CRTs do that, not one or even TVs using CRT
the red gun always goes dim first so we crank it up in the OSD.
if it fails on all PCs, the monitor is bad, a 5 min test. and bingo
then if the monitor is known bad then what.
the OSD screen ever seen that, and the front panel key marked MENU/?
go there and play with brightness, and even the electron gun tuning, the page for that is RGB, Red Green blue.
adjust them so white looks OK.
but if all are dim, that is normal for old CRT,
we only get like 3 folks a year stuck in 1990s... or older.
the labor to fix it is 3 times a new LCD LED display.
land fill time. like the other billion made, and scrapped
Nov 20, 2017 | Compaq Presario 1510 (White) 15 in.CRT...
Monitor shuts down and glows pink
You could try updating the drivers for your monitor and for you video card. It sounds like their could be a hardware problem. When something warms/heats up the connection is made. A pink glow isn't a good thing. Make sure you check all cables and even try to adjust the actual monitor settings Your heat settings for the colors may be out of whack. Last question? Does slapping it a little help? Good Luck. Let me know what happens. Tim
Feb 19, 2007 | Samsung SyncMaster 750S 17" CRT Monitor
AOpen F1713 (Silver) 17 in. Flat Panel LCD Monitor Logo
66 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
