Question about Exercise & Fitness
Does the DP Performer 960 Stepper operate on a battery?
Does the DP Performer 960 Stepper operate on a battery and if so how do I access it?
What should I do when the ignitor of my weber performer does not work?
Replace the battery (if it has one). If all you do is hold down the button and it starts to click then you have a battery ignitor.
Jun 22, 2014 | Weber Performer Grill
Stair master 4400cl Stepper making clunking sound user pedals when stepping
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
This can cause a clunking sound. For the replacement parts, please see the link below.
Why does one Pedal Drop on my Stairmaster Stepper
Apr 03, 2012 | Stairmaster 4400CL Stepper
Where does the battery go in the stair master 4400cl
http://www.sportsmith.net/ Click on your model number for access to an owners and service manual. The below link will also take you directly to the battery for your machine. Battery 6 Volt Stairmaster SM14123 SPORTSMITH net
Feb 15, 2012 | Stairmaster 4400CL Stepper
The left peddle has a periodic quick drop as if it is slipping or something. There is a low popping sound whenever this happens. The drop is very slight and occurs about once a minute.
Mar 17, 2011 | Stairmaster 4400 PT Stair Stepper
Left pedal has no resistance right pedal is fine
Nov 11, 2010 | Stairmaster 4600PT Stepper
I have a stairmaster 4400cl and the right hand pedal intermittently slips and drops to the floor. it only does this a few times every 5 minutes or so. when i put weight back on the left pedal and start...
Oct 17, 2010 | Stairmaster 4400CL Stepper
Electronic monitor operation guide for Proform 3001 stx stepper
Hey Jeff it looks like Icon fitness does not have it on pdf you will need to call the proform division @ 1-888-533-1333 M#.PROFORM 3001 STX STEPPER (PF50180) also have the serial# handy Good Luck!!
Apr 05, 2010 | Exercise & Fitness
Where is 96 volvo 960 fuse for wiper and washer
Fuse panel is below the ash tray in the centre console in front of the gear stick and pulls out (not very accessible)
Oct 15, 2009 | 1996 Volvo 960
Exercise & Fitness Logo
194 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
