Question about Sewing Machines
How do you thread a Necchi Model 537L sewing machine? I can't find the manual.
  • Sewing Machines Master
  • 1,388 Answers
Although your model may not be listed exactly, this link ought to provide other models similar enough to yours to be of assistance.
HERE
Posted on Aug 02, 2009
On necchi model 537L which buttons are for stitch length
It is generally the large knob on the right side about halfway between the top and bottom of the machine. The numbers should range from zero to 4 or 5. Zero is zero stitch length, five would be the largest stitch length.
https://docs.google.com/document/d/1OBOahdPrL29joIvK-_sddWvVcUuOblCc50xn2Q8eZrs/edit
http://www.sewingpartsonline.com/instruction-manual-necchi-537-l.aspx
http://www.sewingmachinemanual.net/Sewing_Machine_Manuals/Necchi/Necchi_537-L_instruction_manual.htm
Jan 09, 2017 | Necchi Sewing Machines
I have a Necchi 537-L and I would like to know the year of it. Any other information that I could get about this sewing machine would be great to thank you for your help in advance
Necchi 537-L Sandi, Machine made in Taiwan, My guess on age would be early 80's. Links below may help, first link one lady states buy her 537L from sears in 1982., other links are instruction and info.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Life With Lou Necchi 537L Sewing Machine
Necchi 536 FB 537 FA Sewing Machine Threading Diagram
http://www.sewingpartsonline.com/necchi-sewing-machine-instruction-manuals.aspx
Apr 03, 2016 | Necchi Sewing Machines
Do you have a demonstration or diagram of how to thread and install bobbin for necchi 537L sewing machine?
Try this web site:
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
May not have your exact machine but one may be similar enough so you can thread your machine properly.
Nov 25, 2015 | Necchi Sewing Machines
Where can i find a manual (free would be nice) for necchi 537L sewing machine?
Ore eBay; see link below.
Some machine are real hard to find, and there are at lease 4 spoof sites that will be glad to take your credit card.
NECCHI Model 537 Sewing Maching INSTRUCTION MANUAL
Mar 20, 2015 | Necchi Sewing Machines
I need an instruction manual for the Necchi Model 537L. My 87 year old mother cannot find the manual. Also, could you tell me what that Model is worth? Thank you
You can purchase a copy of the manual for $10 Here. As for valuation, this is a bit more tricky. Most Necchi's (at least the collectibles) are Italian made. The 537L was made in Japan. There isn't a great demand for this machine nor is it considered highly collectible. You'd be hard pressed to sell it for enough to buy a new machine. If you use sewing machine's I'd suggest keeping it. It was a solid machine. Otherwise, check craigslist and see what other working used machines are going for. I've seen the 537L go for $50.
Aug 14, 2010 | Necchi Sewing Machines
Threading a necchi 537l
There are several Necchi models (and loads more) threading guides shown here, it may well be you can find one very similar to help.
Threading Guides
Mar 16, 2010 | Necchi 3101 Mechanical Sewing Machine
How to thread necchi 537L sewing machine
From the reel pin take the thread to the left and over the top thread guide above the takeup lever, make sure the takeup lever is up and and make sure the presser foot is up, take the thread straight down and round the right hand side of the tension unit and back up the left hand side to the takeup lever, thread the takeup lever right to left and take the thread down any guides to the needle, if the bobbin case goes in the front thread the needle front to back, if the bobbin case goes in the side thread the needle left to right.
Jun 09, 2009 | Necchi 3101 Mechanical Sewing Machine
I need to know how to thread my machine NECCHI Model 537L Necchi 537L I need to see & know how to thread the top thread on this used one I bought, I've ordered a manual, but I need to sew NOW - anyone...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
sewman7
Jan 03, 2009 | Sewing Machines
Sewing Machines Logo
283 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
