Question about Samsung SyncMaster 204BW LCD Monitor
My Samsung SyncMaster 204B has had a blinking power light and absolutely nothing on the screen for awhile. Can I fix it? I assumed I couldn't...
  • 555 Answers
I agree with buddymc, it sounds like a common failure on DELL displays. It may be caused by different causes, here is another example: http://josepino.com/?howto-repair-dell
Posted on Aug 29, 2009
  • Samsung Master
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of the monitor. If you aregood at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Aug 01, 2009
ONLY BLINKING POWER BUTTON ON THE DMONITOR. NOTHING ELSE IS THERE.
This is a common problem with the Samsung 204B units that have been in service for a few years. Parts called capacitors in the power supply start failing and causing the board to not start correctly. The blinking power button is just the power supply restarting over and over. The monitor is easily repairable, you just need to replace the 5 capacitors that have failed. Here is a link to a page that shows how to open the monitor, get to the power supply board and what to replace.
http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/
BuddyMc
Sep 17, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
SyncMaster 204B screen appears in 5 min after turning monitor on. First 7-10min screen is dark and slowly increases brightness. The picture becomes normal in 15-20 min and all is OK until the monitor is...
How long have you had the monitor. It sounds like a defective backlight. Usually when the circuit driver for the backlight starts to go bad, the monitor will blink. If this is the case, eventually the monitor will not turn on at all.
Jan 12, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
My SyncMaster 204B Monitor just stopped working. It worked fine this morning before I left for work, but when I arrived home, it wouldn't power up. I've been Duel Screening for about 2 yrs with no problems...
Replace the screen with a known working one. If it shows display then it is the screen which is broken, if not, then it could be the port on which it is connected.
Feb 25, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 204B The blue power button is on but the screen is black. When I turn it off and back on it shows the screen for a second then goes black. Can you please help me. Thanks
Got the same problem, happened yesterday for me, Did some research and it looks like its bad capacitors in the back, check out this page for more information... i'm taking mine to an electrician to fix today... luckily he's related and should be able to fix it on the cheap...
http://pavel.kirkovsky.com/blog/2009/03/samsung-syncmaster-204b-repair/
Apr 02, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
Feb 10, 2009 | Soyo DYLM1986 Monitor
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
I had a similar problem on a different monitor and fixed the green sparkles by selecting a lower refresh rate.
Aug 15, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung Syncmaster 204B
Try to replace C110 and C111 in the power supply circuit. These are 820uF caps and are in parallel. I had slow start and a flicker on this same monitor. Replacing the caps fixed it. Good luck, Ryan
Jul 09, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Black screen; blinking power light
are using dvi cable did u try to hit the input botton on screen itself thx nick
Feb 07, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung syncmaster 204b
Yes. There is no vertical deflection. The circuit that controls vertical deflection is bad. This is an easy fix for a TV tech. Take it to the TV repair shop.
Dec 14, 2006 | Samsung SyncMaster 204B 20.1" LCD Monitor
Open Questions:
Samsung SyncMaster 204BW LCD Monitor Logo
394 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
