Question about Electrolux Frigidaire Affinity AGQ8700FE Dryer
I'm finding pinholes in my clothing.
I have run my hand over the entire interior of the dryer and I can't find anything sharp
  • 10,865 Answers
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Posted on Aug 01, 2009
    President:
  • 2,976 Answers
I'd be more suspicious of what you're putting through the wash, rather than the machine.
Kenmore 110.66902690 electric dryer does not dry completely
Dear Barry,
Try 2 things.
One, be certain the clothes are very dry coming out of the washing machine.
If the washer leaves the clothes wet ( like the belt might be slipping), it can take the dryer forever to finish drying the clothes.
You can tell by hand-wringing them.
You should not be able to get any water out of them by hand-wringing after they have spun dry in the washer.
Two, try running a load with the vent hose unhooked off the back of the dryer.
If this fixes the problem, you are having a "clogged vent" issue somehow.
Be blessed.
Apr 16, 2013 | Dryers
I just bought one gas dryer-MDG17MN. why it takes so long to dry the clothes, it takes almost 2.30hrs to dry 4kg clothes.
remove the front cover and clean out the entire interior unit including the air flow duct workany restrictions in a gas dryer especially will increase dry time considerably
Sep 11, 2011 | Dryers
It is not drying the clothes. After the time limit runs out the clothes are hot but not dry.
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state, or having improper air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. Eventually, this can lead to component failures and is the source of many fire hazards.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Oct 06, 2010 | Estate EED4400WQ Dryer
Heats up but will not dry cloths
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks or clogs. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards. If you have any questions, please post back with a complete MODEL NUMBER and let me know. I hope you find this information helpful.
Jul 08, 2010 | Kenmore 500 6952 Dryer
I have to run my clothes through 3 to 4 cycles to get them dry. The dryer is not over or underloaded.
If your dryer IS still heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks or clogs anywhere. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to actually overheat. Eventually, this can lead to component failures and is the source of fire hazards. If you have any questions, please post back and let me know. I hope you find this information helpful.
Jun 22, 2010 | Amana NED5100TQ Dryer
Dryer is heating but not drying the cloths, not even small loads
If your dryer IS still heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire exhaust duct run to ensure you have no clogs anywhere. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
If you have any questions, please post back an let me know. I hope you find this information helpful.
May 26, 2010 | Roper REX3614KW Electric Dryer
Maytag electric dryer model # MDE2500AYW
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance:
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 08, 2008 | Maytag Dryers
My ge dsxh43 dryer is chewing up clothes and leaving brown burns on the end.what can i do?
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
Here are some things to look for:
Rollers
Rear seal
Front glides
Front seal
Thank you,
Dave E. (Illeagle)
Jul 07, 2008 | Dryers
Torn clothes
Rollers
Rear seal
Front glides
Front seal
Thank you,
Dave E. (Illeagle)
Mar 30, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Snaged clothes
Check the lint trap on the dryer. We had the same problem and it was because we put the lent trap in backwards.
May 01, 2007 | Kenmore 94802 Front Load Stacked Washer /...
Electrolux Frigidaire Affinity AGQ8700FE Dryer Logo
291 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
