Question about E-Machines eMachines Desktop PC
Windows wont boot. switches to a screen with reasons why not and options to try but none of them work emachine model w3644. tried using recovery discs burnt from one of the other w3644 models we have but that gets to 39% and starts recovery all over again
  • cindy3_5_57 Aug 01, 2009
    Windows operating system will not come up therefore I can not access the system restore that is in my start up menu.
  • 99 Answers
Try to find a system restore on the computer without using the disks. Restore it to a previous time maybe a month ago if possible.
Posted on Aug 01, 2009
Trouble with complete restore on eMachines W3619
may be you can try to fix the issue by software, and restore your system by a recovery disk. Windows Boot Genius may be available to you.
Jan 21, 2013 | eMachines W3619 PC Desktop
Restore my emachines w3507 back to factory settings how do i do it
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
or
It is possible for the Windows operating system on your eMachines computer to have a critical failure. If the operating system on your eMachines computer is failing, you can use your recovery discs to restore your computer. Recovery discs come with your purchase of an eMachine, and contain your operating system and all your basic drivers. You can recover your eMachines W series in about an hour.
Turn off your computer and press "F8" to enter the BIOS menu. Tab over to the "Boot Sequence" or "Boot Order" menu. Move your optical drive to the top of the list. Press "F11" to exit and save changes. Insert your recovery disc into your optical drive, then restart your computer. Press any key to boot from disc. Select the "Full Recovery" option from your recovery disc menu. Allow the recovery procedure to complete. Hope this helps.
Dec 28, 2012 | eMachines W3507 PC Desktop
Acer aspire 5736Z wont boot on any recovery options
Try starting up in Safe Mode (Console mode) and type in
"SFC /Scannow"Once its done you should be able to do recovery options.
If not, boot from the windows 7 recovery/install CD and choose "Repair".
Go through the recovery process using the CD and it should all be fine!
Dec 26, 2012 | Acer Aspire 5736z 4460 Laptop
How to erase data to factory system default on emachine t3504 i t says to hit start then click all programs then click emachine but that heading isnt on list
If your computer has a recovery partition on the hard drive to as follows:
  1. Restart the computer
  2. When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If your model does not have a recovery partition then you were given the option to make your own recovery CD's. Unfortunately if you did not do so then you will need to contact eMachines to see if they will sell you recovery CD's. I used to sell these models and as I recall they did not come stock with a restore CD.
Jul 10, 2011 | Computers & Internet
My hp mini 1000 wont boot up. when i turn it on it goes right to a screen that asks how i want to start up windows ( safe mode, safe mode with networking, safe mode with command prompts, and start windows...
hi blinkgirl556
was there a new hardware that was added to your laptop? bluescreens often are caused by hardware.
while the laptop is booting up when you are asked for options on how to start you computer is there an option for start windows using last known configuration? if there is try that and if it still goes into bluescreen you may want to try and recover your laptop using the hp recovery cd or recovery tool. if it still doesn't work most likely you have a bad memory chip.
hope this helps
contact me for any updates
janc30
Feb 08, 2011 | HP Mini 1000 Netbook
MY EMACHINE DESKTOP RECOVERY CD DOENT WORK
Hello
When booting up pc have you held the delete key or f2 key down to bring up the boot menu?Should be a option of cd dvd or hdd to boot first.
You want the cd dvd boot option on top or first.tThen reboot pc.
When asked hit any key to boot from cd, hit a key.Should start install.
If youve done this, clean the dvd or cd install disc with some windex and a paper towell,try again.
You can also do a system restore from control panel recovery option.
Jan 23, 2010 | E-Machines eMachines Desktop PC
Windows Vista Will not load correctly
sounds like you have some corrupted files in the boot sector. 2 options.
1. using a vista dvd: let it boot from dvd and when it is loaded select the repair my computer option. once you get up and running use malwarebytes and superantispyware to remove any nasty bugs that you may have caught.
2. using your recovery partition do a system recovery this option restores your pc back to when you bought it.
Aug 29, 2009 | Toshiba SATELLITE Notebook A205-S5813
A305 keeps rebooting
You could have a few different issues.
1. You have a driver issue. Try running windows repair from Microsoft install disk.
2. Possible power supply issue.
3. Bad hard drive. Possible bad sectors. Nothing to do here but replace hard drive.
Try disconnecting all hardware in system except hard drive and video card. This will include network cards and any other peripherals. Try to boot up.
Jun 23, 2009 | E-Machines eMachines Desktop PC
Restore emachine
Your machine has two ways of repair: SYSTEM RESTORE and SYSTEM RECOVERY. System restore is a Windows utility that rolls the machine back to a point where the machine worked before the problem. System recovery is an eMachines tool that puts the machine back the way it was when you first got it. Restore wont delete your data, recovery will and can. If the problem is catastrophic, and youve backed up your data off of the machine, use the recovery option. Your recovery partition (or a recovery disk) is needed to do this, and it involves pressing a key while the computer boots up. Check your documentation for your model of machine.
Mar 24, 2009 | E-Machines (T2824) PC Desktop
System Recovery message appearing during boot up for no apparent reason
The change would be in your bios i believe. are you comfortable with working in there ?
Robert
Aug 20, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
353 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
