Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirpool Washer LSQ9500LQ0 Won't Spin or Drain
My washer won't spin or drain. It will agitate and add water. The lid switch seems shot however I bypassed it by wiring the leads together. The timer still runs through but the spin and drain won't kick in.
And oddly enough my Whirpool LER6611LQ0 Dryer conked out last night too. I think it's the belt. It heats but won't move and the tumbler just spins around.
  • js4574 Aug 02, 2009
    I touched the wires together. All i hear is the timer clicking on and off. The timer is still running. Where is the solenoid? Is is on the control panel? The timer is sounding nasty but it is running and if you switch it into fill or agitate those cycles will run.
    Update - i hotwired the switch and got the washer into high spin and drained the tub. Won't work in a low spin. I'm wondering if the timer is on the fritz or is it the gearbox.
    Brigadier General:
  • 4,088 Answers
Your belt assessment sounds correct on the dryer problem.
If you can, restore the lid switch connections, and operate the switch during what should be spin. You should be able to hear a relay or solenoid clicking off and on with the switch.
Posted on Aug 01, 2009
  • drallim Aug 02, 2009
    It acts like the gear box may be ok as it seems to be performing most of the required functions, but in a haphazard way leading one to suspect the timer control unit. If there is a solenoid, it would be on the transmission (gear box).
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
My washing machine is a whirpool stylemaster model no. LXR9245EQ2 and it will not do anything besides put the water into it and it will only halfway drain. It does not agitate at all.
If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically.
Here is the switch to order.
The part comes with a 365 day, any part, any reason return.
Nov 07, 2012 | Washing Machines
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
695 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
