Question about Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer smells musty. what is
My maytag neptune washer smells musty. what is wrong
    Problem Solver:
  • 16 Answers
I owned a maytag neptune washer and had to run dishwashing liquid thru it occasionally to get the smell to go away. Finally we learned about a new gasket retrofit that they were doing which was covered by the maytag company we called and they installed it for free and the smell stopped. I had that washer for about 10 years and probably spent as much fixing it over the years as it cost. I now have a whirlpool duet front loader and love it. no smell and not problems. Try the electric dish washer soap.
Posted on Aug 02, 2009
My washing machine sounds like it still has water in it when i spin it and it smells musty
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
How do I get rid of mold in the front rubber part?
There are many things that will get rid of it, the most effective is a diluted bleach and a green scouring pad.
Jun 07, 2011 | Maytag Neptune MAH5500B Front Load Washer
Musty smell
Try running a large load without clothes using the hot water cycle and add a cup of white distilled vinegar.
May 30, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune smells very musty. I have used vinegar, baking soda, and bleach but the smell wont go away!!!
This is gunk build up under the agitator and/or the drain area under the drum. It needs to come apart...
Apr 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag front load washer - smell musty
the water in the unit is normal, to kill the smell when you are done doing wash for the day dampen a rag with bleach and whip down the door gasket. You can buy a cleaner called "afresh" it works as well. If your unit is a neptune check with maytag it might have a recall on the door gasket for growing mould
Nov 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
There seems to be water left in the machine. When
Water gets inside the top plastic ring on some machines. You would need to remove the inner tub to get at it to empty the darned thing!
Oct 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
I noticed that my clothes are not smelling fresh, especially my towels. The washer has a musty smell even after running it with bleach. When I shake the washer when it is empty I can hear water. Is this...
if it is a Maytag neptune YES that sound is normal. especially when you rotate the drum by hand that is your balance ring you are hearing. Do you only use liquid detergent? if yes this might be your problem. it leaves a film around the drum. i would run 3 wash cycles with bleach and hot water. and then at least once a month with hot water and bleach to keep it fresh and also leave the door open so that it can air dry oder causeing bacteria love moisture.
Oct 24, 2009 | Washing Machines
Clothes washer does not drain completley
Clear the filter and the pipes between it and the pump, tip the machine back and look under you will see a black pipe from the filter to the pump. Simply remove the pipe and clear it and the pump while your there.
Aug 23, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune washer has bad odor, city water.
There is no filter in your washer that would cover the odor issue.
The website link below will give you all the information concerning odors in a Maytag Washer
http://maytag.custhelp.com/app/answers/list/kw/odors/p/293/r_id/108284/sno/1/search/1/session/L3NpZC9RRDdZdDhEag==
Jul 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water seems to be left in bottom of washer
This is a Maytagism for this style of washer.
Quick solution... take a terry towel and wipe out the standing water in the front door seal area and when you're done, toss the towel into the wash load.
Also make the loads a little smaller...it will keep the smell from reoccuring as much.
Jun 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
2,419 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
