Question about Ebac BD150 Dehumidifier
Can I leave my ebac bd150 unattended all night?
Can I safely leave my ebac bd150 unattended all night?
Ebac 2650e dehumidifier manual
Try Googling (ebac)(2650e)(manual) without parens.
Jan 22, 2018 | Ebac Dehumidifiers
Can i get user instructions for ebac Z850E
This site might be able to help you. For the ebac 2850E manual. I could not find a "Z"850E
Dehumidifier Instruction Manuals User Guides
Nov 16, 2016 | Ebac Dehumidifiers
Dehumidifier starts, stops, starts, stops, then runs normally.
ive seen this happen on a unit that start ckt capacitor was going bad (swelled) it finnaly gave up and started no more , if unit is more than a few years old then seek a replacement as if start ckt is really at fault here then a overheat condition could result , this is not safe to just leave unattended
Oct 01, 2014 | Dehumidifiers
Need wirring daiagram
Here is a link to your Owners Manual, which should have the electrical schematic in it.
www.ntsupply.com/files/products/BD150_manual.pdf
Hope this helps you.
Apr 29, 2011 | Ebac BD150 Dehumidifier
Ebac 2850 made rumbling noises and shook now not working at all
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 01, 2010 | Ebac Dehumidifiers
MY 150 FREEZES UP NICELY BUT DOESN'T DEFROST EVEN AFTER 1.25 HOURS.ANY HELPFUL ADVICE?
room temp is 60 or colder - may need to put space heater 2 feet away facing air intake. If this unit has defroster, fuse may be blown
Nov 30, 2009 | Ebac BD150 Dehumidifier
Compressor won't start
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Jul 29, 2009 | Ebac BD150 Dehumidifier
My unit has started to trip the circuit breaker
the fan bearing is siezed / check if fan turing freeley
Jun 15, 2009 | Ebac BD150 Dehumidifier
Documentation for Ebac 2400E required, please.
Is it possible to download -PDF the Instruction Manual for the Ebac dehumidifier model 2400
May 19, 2009 | Ebac Dehumidifiers
User instruction
Here is the link for the Owner's Manual off the Ebac website:
http://www.ebacusa.com/technical/Manuals/HD.pdf
Jun 30, 2008 | Ebac HD880 Dehumidifier
Ebac BD150 Dehumidifier Logo
94 people viewed this question
Top Ebac Dehumidifiers Experts
Bill Long
jasbo
jasbo
NOEL
NOEL
Are you an Ebac Dehumidifier Expert? Answer questions, earn points and help others
