Question about Refrigerators
Model ED2500XDN86 Side by Side Refrigerator/Freezer. Ice maker in the freezer side does not work. Water does reach the water faucet in the door.
I gave up on fixing it myself and called a Whirlpool repair service. Your
service was very helpful, however, I decided that I could better use the time working on a new business I am starting.
Thanks for the help!
bill52132x@hotmail.com
Posted on Aug 02, 2009
Ge refrigerator ice maker has stopped making ice
The water valve on the back of the refrigerator is bad, one controls water for the ice maker and one controls water for door water
May 11, 2014 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
How long after hooking up ice maker does it take for the water to start running in. we have water in the door water just not in the ice maker?
Should have started to fill soon after freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice approximately every three hours. The above was in the user manual and only answers when the process begins. There is a thermostat embedded inside the ice maker that tells the water control valve for ice maker to open for approx. 7.5 seconds. Because this model has a freezer below the left fresh food section light switch has an interlock that completes 120VAC to the ice maker once the fresh food section door is closed. Defective fuse, door switch or ice maker will make operation impossible until the problem is located. Please let me know if you need assistance beyond the above here.sea_breeze_27.jpg
Thanks, Sea Breeze
Dec 16, 2010 | Amana ASD2620H Side by Side Refrigerator
Ice Maker does not work.
Check the line going to the ice maker for clogging.
Sep 25, 2009 | Kenmore 57029 Side by Side Refrigerator
My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
May 23, 2009 | GE GSH22JFR Side by Side Refrigerator
Ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool gold ice maker problem
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool icemaker not working
the refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser. the valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
another thing that could cause it would be the temperatures in the freezer. the ice-maker will not call for water until it reaches under 15 degrees.
Jun 12, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
