When the water comes out of my clothes whirlpool
When the water fills up my whirlpool clothes washer, it smells aweful. It seems to be worse when I use hot water.
  • 99 Answers
If it is the water itself have it tested, if it is the washer that is stinky then run a wash cycle with 2 cups of white vinegar or even more without clothes in it and see if that helps.
Posted on Aug 01, 2009
Water leak at bottom of Whirlpool Estate washer. Removed the cabinet. No leaks from the water pump, hoses or inlet valve. The tub leans a little toward the front of the machine. When filling/rinsin
It is common on Whirlpool models for the water to splash out the top when filling especially when sheets or nylon cloth is loaded in the washer. Air fills the cloth and balloons the garment up this caused water to bounce off the garment and splash out the back. This is the most common reason for those mysterious leaks. Lowering the water pressure coming into the washer can help prevent this.
Jan 25, 2015 | Whirlpool Washing Machines
Stagnent water smell while filling
I found that running about a quart of white vinegar through a cycle with hot water and no clothes or detergent takes care of the musty smell. Vinegar removes detergent build-up.
Nov 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool cabrio washing machine. I have a problem. Our clothes are coming out smelling musty and nasty. They dont start smelling until they are wet, like with sweat Or the towels when we dry off...
If you dont wash whites with clorine bleach, you may want to every once in a while. Clorine kills germs and backteria which can smell. washer pumps do not get 100% of the water out.
Sep 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a quite normal front load whirlpool washing machine and the feeling when I clean my clothes is that the smell is that fresh smell anymore, does not smell like softener or any soap but a horrible...
Oh angel!
a rose by any other name!
If your clothes smell worse after washing then the machine is full of gunge from all the previous washes. One of the worst things that puts a gluggy deposit inside machines is of all things Softener!
You could try putting a generous two cups of Sugar Soap Concentrate into your machine and filling it with warm water. Then let it stand for 24 hrs, Then start the wash cycle.
This may clear the gunge. If not the only sure remedy is a strip down and degunk and that will cost you a few dollars.
Oct 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Calypso Washer: No water fill intermittent
Check the hose from the tub to the pressure switch, make sure its clear and the reservoir on the tub is clean.
Oct 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG washer uses so little water, clothes aren't even damp and not clean
You will need to have a qualified LG technician come out and see what the problem is.  You may have a water level switch issue.
Jul 11, 2008 | LG WM1815CS Front Load Washer
Liquid Bleach dispenser doesn't work correctly
This may not be relevant, but by design, bleach does NOT dispense in the Buly/Bedding, Kids Wear, and Silk/Ultra Delicate cycles. If you try to use it, it remains in the dispenser.
As for the yucky smell, leave the door open when not in use.
Nov 16, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer smells like stagnant water
Open the door and let it air dry between washes doesnt have to be wide open but not latched either also run a hot wash with no clothes and 1.5 cups of bleach (pour bleach in the tub after it fills not in the bleach disp)
Sep 28, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Filling
have u got the echo-fill button on if it is it will only fill up with very little water other than that without seeing it cant say
Aug 12, 2007 | Zanussi IZ12 Front Load Washer
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
