Question about Casio QV-R40 Digital Camera
QV-R41 Problem Hi,My camera's screen doesn't show anything except black screen when in the capturing mode.But it can show images in the picture preview mode..Please help.Thanks,Ned
Try hitting the display button on the camera.
Posted on Jun 08, 2009
  • 374 Answers
Sorry Ned, that is something that is going to have to be sent in to repairs. There is nothing we can do ex. resetting to fix that.
Posted on Nov 26, 2007
SONY DSC-T1 CAMERA WHEN TURNED ON PREVIOS PICTURE SHOW UP FINE ON THE VIEW SCREEN BUT WHEN THE THE SELECT MODE SWITCH IS MOVED TO EITHER TAKE A NEW PICTURE OR TO MOVIE MODE THE VIEW SCREEN IS MOSTALLY...
Based on the information you've provided it seems that the CCD Image Sensor of the Camera is affected. If the CCD Image Sensor is affected, the images captured may be discolored or with lines on it. Even if the CCD is affected, the previously captured images and icons of the Camera will display normally. You may try power resetting the Camera.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
Also try resetting the Camera back to factory default: The RESET button is located at the lower right side of the control button. To reset the camera just press the RESET button using a sharp-pointed object.
If the issue remains the same, then service may be required.
Thanks for using FixYa.
Mar 01, 2011 | Cameras
I have a Casio QV-R41 camera and it won't turn on
Just do the following steps which is very simple to fix your problem. Take a paper clip and if you look in the battery casing there will be three brass conductors if thats what you call them. Just bent them up to make sure that there is contact between the battery and the metal positive and negative and it will work for you.
Thank you !!
May 23, 2010 | Casio QV-R41 Digital Camera
Panasonic Lumix DMC FX12
HI,
It's impossible to turn the camera off. Only way is take out the battery.
No button warks, but I can change the shooting mode and turn playback, but I can't change the image in playback mode.
Please, help me to solve this problem.
I think, the camera needs to be restarted, but how to do that?
Thanks a lot.
Jun 17, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
Image not visible on monitor screen
you need to install camera drivers and application software again.
Oct 22, 2008 | Casio QV-R41 Digital Camera
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Green output
WHAT HAPPENS WHEN I DOWNLOAD THE PICTURES ONTO THE COMPUTER ,WILL THEY STILL GIVE ME THE SAME COLOUR, GREENSH ONE?
Jul 25, 2008 | Casio QV-R41 Digital Camera
Black screen, not capturing photos
have the same problem...
it happened about a month ago and i pressed the display button and it worked, but now that doesn't work either!
Jul 22, 2008 | Canon PowerShot SD1000 Digital Camera
Problem
Two things to try...
A) If you have a card with some photo's on it then put it in the camera... Will the camera display the photos from the card in view/play mode? If so then the screen is working but the sensor in the camera may have died (the but that captures the image).
B) Try taking a picture with the camera (go through the steps to take one even though you can't see anything on the screen). Then put the memory card in a reader or a friends camera and see if the picture did get taken. If so then the sensor is still okay and the fault may be with the display.
If the display will show images from the memory card but doesn't show anything when in picture-taking mode but the camera does take pictures then the camera has a fault that isn't either the sensor or the LCD. It could then be an electronic failure or a problem with the mode selection switch.
Hope this helps to figure it out.
Cheers,
TS
Jan 04, 2008 | Panasonic Lumix DMC-LZ3 Digital Camera
Strange picture appears in CCD
I see this problem everyday : the CCD sensor is faulty ( see enclosed pic from a canon camera with similar specs ) this is why you can not capture normal undistorted images but have no problem with playback .Fortunately Casio will repair this free of charge so contact your agent.1057f04.jpg
Nov 14, 2007 | Casio QV-R41 Digital Camera
SD card problem
Format the SD card using camera's format function. The SD card should work without a problem. BTW, what do you mean by Camera type: Qv-R41/Qv-R51? The camera should be either 41 or 51. 41 is 4MP and 51 is 5MP. Which camera do you have?
Sep 12, 2005 | Casio QV-R41 Digital Camera
Casio QV-R40 Digital Camera Logo
177 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
